rear deck filler panel removal ?
Discussion in 'Body Restoration' started by fnoblitt, Feb 14, 2021.
  1. fnoblitt
    fnoblitt Veteran Member
    405
    Jul 4, 2009
    riverside calif.
    i have a broken rod to replace that holds up the trunk lid. how do you remove the filler panel for access ? do i have to remove the back window first ?
  2. badazz81z28
    20,557
    1,381
    Alabama
    Negative, remove the rear glass trim and you will see the screw holding it down. I'm not sure if the filler panel can clear the car with the trunk lid installed. You might need to remove the trunk lid.
  3. fnoblitt
    405
    Jul 4, 2009
    riverside calif.
    ok, thanks, i'm swapping out trunk lid as well
  4. lapedr
    lapedr Veteran Member Gold Member
    667
    23
    Jan 28, 2003
    Pembroke, GA
    Protect the rear window with something that can take a hit from the torque arm just to be safe, maybe some plywood and a uhaul blanket.
