rear end question
Discussion in 'Transmission & Driveline Topics' started by younda, Mar 14, 2018.
  1. younda
    younda Veteran Member
    182
    58
    Jun 26, 2015
    MA USA
    I wanted to find a 3:42 posi for my 74 Z28 and found one from a 1980 Z28 parts car. What's the difference besides the stamping on 74 vs. 80? The reason for asking is I found a correct CM code 74 but the price is very high and the 1980 is very reasonable.
  2. Gary S
    23,789
    1,448
    1980 should have a PY coded rear for 3.42 posi. Other than the code, the rear end should be basically the same as the 1974 rear ends.
  3. slayer021175666
    slayer021175666 Veteran Member
    1,320
    80
    Feb 29, 2016
    Idaho
    Its the same. Buy it.
  4. 74BIBELOT
    74BIBELOT Veteran Member
    865
    57
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    Check the pinion yoke, could be different, but you can use the appropriate u joint.
  5. Green hornet
    Green hornet Veteran Member
    2,008
    466
    Oct 11, 2015
    North Bay, CA
    If it fits your budget by it. What would be the reason for purchasing correct code one?
  6. big gear head
    big gear head Veteran Member
    6,398
    172
    Jul 30, 2001
    Central City, Ky.
    The pinion yoke will be different. The '74 will use a 1310 U joint and the '80 will use a 3R U joint. You will need the '80 drive shaft or you will have to use an adapter U joint in your drive shaft. Also, the mounting bracket for the rubber brake line will probably be in different location.
  7. NoneToPass
    NoneToPass Veteran Member
    1,026
    9
    Jan 4, 2000
    Columbus, Ohio, USA
    Yep, the 80 bracket is welded to the drivers side tube and the 74 mounts to the diff. cover. Brake lines can be swapped over from your current rear and disregard the 80 bracket.
  8. younda
    182
    58
    Jun 26, 2015
    MA USA
    67CFC4CE-D93D-4C4F-8D55-B424E99CE3F0.jpeg 8A08D0CB-CB70-4F34-8CD5-9E8021E7295D.jpeg Thank you for the information. I got the PY with only 50k miles for $350. Got the history of the car which was in a garage for over 25 years.
  9. ZEN357
    ZEN357 Veteran Member
    384
    71
    Feb 12, 2018
    Should be the same. I would buy it.
  10. tom3
    tom3 Veteran Member
    13,307
    927
    Aug 1, 1999
    ohio
    If needed your local NAPA dealer can furnish the conversion U-joint if you can get the measurements or part number for them.
