Rear end ratio and tire size
Discussion in 'Transmission & Driveline Topics' started by Elliott Taylor, Jun 13, 2021.
  1. Fbird
    5,793
    1,682
    Feb 12, 2011
    atlanta, ga
    yes around 27" tall. On cars you can't really move things tooooo far unlike a truck. Basically if you go up 1" thats only moving your total mph 3% (give or take) so at 60 ...thats +/- 1.8 mph...not a big deal.
    On a truck that has 31" then you go to 36" ...that is a 17% jump...to + 10 MPH @ 60 (truck would be doing 70)
  2. Elliott Taylor
    Elliott Taylor Member
    87
    Nov 24, 2020
    Considering you can't really move up too much in height like you say, would you also say going with a taller tire won't affect the rear end too much ?
  3. biker
    biker Veteran Member
    3,959
    1,885
    Dec 7, 2014
    No. Even a 2" taller tire will affect the overall ratio very little. You may notice a very slight difference when starting out in 1st gear if you have a manual trans, but an automatic with a properly matched torque converter wont even blink.
  4. Elliott Taylor
    87
    Nov 24, 2020
    I actually have a manual, so I won't anticipate much difference. Thanks for the info!
  5. 74RAT
    74RAT Veteran Member
    3,401
    Dec 28, 2003
    ft. stockton,tx,usa
    Rpm = (mph x gear ratio x final drive x 336) divided by overall tire diameter
    Don't forget the slip of an auto trans converter, when it's not in lockup.
  6. RTSE
    RTSE Member
    53
    11
    Apr 11, 2020
    I changed my diff ratio from 2.42 highway gears to 3.91 I had to run 17” wheels as I converted to 4w disc brakes with 13 corvette discs on the front. Still running a TH350, speedo is way out but am installing a 4sp overdrive auto so that should even it all out
  7. Fbird
    5,793
    1,682
    Feb 12, 2011
    atlanta, ga
    check out speedway for a speedo drive "fixer"....little gear convertor to fix your speedo..
