Rear-End Upgrade Plan, Sanity Check Requested!
Discussion in 'Transmission & Driveline Topics' started by wpatterson9, Jan 9, 2021.
  1. big gear head
    big gear head Veteran Member
    6,367
    158
    Jul 30, 2001
    Central City, Ky.
    Find out how they intend to weld it. If they are going to MIG weld it with steel wire then pass on it. If they are going to stick weld it with steel rods then pass. Welding cast iron must be done right or don't do it at all.
  2. 67johnny
    67johnny Veteran Member
    255
    12
    Apr 14, 2016
    vancouver
  3. Lowend
    15,963
    994
    Mar 25, 1999
    San Jose, CA, USA
    It's not a huge change.
    Figure a 1 deg chang on a 24" run is only 13/32" at the furthest point
  4. hd_cat
    hd_cat Member
    67
    17
    Sep 6, 2013
    United States
    My advice is to consider the cost of upgrading the existing rear end assembly and compare to a crate assembly. The amount you mention $1K is around half the cost of a crate rear end assembly. Depending on how you drive, you might consider aftermarket axles, C-clip eliminators would be a good investment as well. I chose the Strange 12-Bolt assembly with 3.73:1 Gears, yes it's expensive, but I should never have an issue with breakage. Regardless of the path you choose, strength/durability should be number 1, if you're not racing, consider the gear ratio, the 3.42 for the 8.5" ring gear 10-bolt is a great option for a mild engine, you won't believe the difference in acceleration, but your highway RPM will be significantly higher. Don't forget to change the driven gear for the speedometer, which should be a direct swap, if you choose the ratio from the factory options (3.08, 3.42, 3.73). Good luck with it, I'm happy with my choice and should only have to maintain it for the life of the car. The photo shows the installation with a 1" Addco Swaybar.
  5. big gear head
    6,367
    158
    Jul 30, 2001
    Central City, Ky.
    Yes, it can shorten the life of the gears and axles. I've seen rear ends that were bent slightly and the whole differential was bound up so that it wouldn't turn free. I also know of a guy who had his rear end narrowed and the guy didn't get it exactly straight when he welded the ends on and the axle splines wore quickly.
  6. muscl car
    23,042
    1,551
    Jul 8, 2001
    SoCal High Desert
    For just over $4k you can get custom built to your specs Ford 9" axle from Quick Performance like mine i had built by them
    Axle housing ...Chromemolly axle tubes and billet steel big bearing housing ends
    Billet steel housing
    Welded on bracing to increase structural strength
    Heavy duty billet steel leaf spring perches
    Center section ... Yukon aluminum carrier
    Billet pinion support
    Billet yoke
    Billet full spool
    3.89 gears
    Axle shafts .... 35 spline hvy duty axles
    S10 disc brake conversion
  7. wpatterson9
    wpatterson9 Member
    44
    8
    Apr 18, 2011
    VA
    @big gear head , Will do and thanks for the heads up. I'm hoping the shop will come through. They've received many positive reviews and specialize in muscle cars. If not, no big deal, I've got a few other places around here that could do the work but are 45min to 1hr away. Not opposed to traveling for good work but if the same quality is right by, all the better.
    @hd_cat , Thank you for the advice and your setup looks great! I did price out the cost of buying new vs. rebuilding what I have. After I compared both, I found that I'd be able to come out ahead slightly if I buy the parts and pay for the labor to install. At one point I did consider doing the labor myself but the wall I wasn't going to pay to overcome was purchasing the measurement equipment. I couldn't really justify buying tools that I would use only a handful of times. The plan for my build is going to keep the car relatively mild; 400-450 HP at most. Add that with the fact that my days of being a 6' x 225 lb. invincible 20 year old fueled by piss and vinegar are long, long gone... I'm thinking the car should be able to stand the test of time.
    @muscl car , That is a nice setup!!
