Rear-end vent?
80Zcorn
677
Israel
I searched for a vent on my diff. Didn't find it.
Is it mandatory? Am I missing some
20161019_130433.jpg 20161019_130446.jpg 20161019_130459.jpg 20161101_132751.jpg 20170609_150102.jpg 20170609_150204.jpg 20170609_150235.jpg thing?
camaro71/holland
1,648
The Netherlands
There should be one somewhere on top on the flat area towards the pinion. Maybe someone closed it off and it's under the dirt.
You should have a vent, otherwise if the oil gets (too) hot and builds ups pressure, it will find it's way out through the weakest link: seals.
80Zcorn
677
Israel
So there's obviously not in my diff.
Were there any diffs without ventilation?
Is it possible that someone clogged it? Should I drill it if then?
80Zcorn
677
Israel
If you're positive there's no venting at all, you can drill and tap the top of one tubes and install one there.
Tapping? As I understood from other posts here, it should be pressed, isn't it?
I’ve never heard of a diff without a vent. Like already mentioned might be concealed by dirt.
I'll try to give it a better clean-up and search again. Thanks.
Stephen Maggard
It should be a plastic piece sticking up in our 5th picture on the upper flat spot above the fill plug. I would assume it had been broken off and covered with gunk, try cleaning that area and see if there is something under there.
