Rear glass install - butyl tape vs urethane
Discussion in 'Body Restoration' started by Allison Winn, May 9, 2021.
  1. Allison Winn
    Allison Winn Red70Z
    250
    44
    Jan 10, 2021
    I had my 1970 rear glass professionally installed. The guys super cleaned everything, used correct pinchweld primer, used 3/8 butyl ribbon, set the glass and all was good.
    Then I started working on setting the trunk lid and filler gaps and such. In doing so I removed the 2 small spacer blocks and forgot to put them back in. Over the next week the glass "slid" down until it is touching the filler panel and completely off the upper pinchweld butyl tape. YEP it came off the butyl completely and like it was never stuck. No residue on the glass and the exposed butyl isn't even sticky.
    So I am rethinking the re install. Has anyone used the special modern urethane glass adhesive on old school cars?
  2. Twisted_Metal
    30,062
    2,784
    Yes, urethane can be used on our Camaros.
    It’s not a “DIY” project.
    Make sure the trim fits properly before the urethane sets up.
  3. COPO
    21,095
    2,616
    When I had butyl both my front and rear windows sunk and left a large gap between the glass and trim.
    In ‘85 I had both front and rear glass done in urethane. Both glass’s have not moved. Don’t use butyl.
    biendog likes this.
  4. badazz81z28
    21,031
    1,484
    Alabama
    If they used Butyl, it was not professionally installed...lol.
    The OEM from the factory did in fact use urethane to install the front and rear glass. GM did not use butyl on 2nd gen camaros.
  5. RickM
    RickM Veteran Member
    683
    145
    Apr 16, 2004
    Gaithersburg, MD
    Correct in my 81 Fischer body manual it clearly states that urethane is what should be used, front and back.
  6. secondgenaddict
    secondgenaddict Veteran Member
    424
    199
    Dec 29, 2012
    Upstate South Carolina
    The glass should have been cleaned and should have the primer applied to it as well, that is probably why it slid... however as stated Butyl was only used for a strip about 6-8" long bridging the area where the antenna lead comes from the center of the glass.
  7. badazz81z28
    21,031
    1,484
    Alabama
    My 70 03B car still has the original rear glass, secured with cured urethane.
  8. G72Zed
    G72Zed Veteran Member
    3,131
    1,583
    Sep 8, 2015
    No, it was not professionally installed. Your "rethinking" is correct.
    Get a true Pro the next time, the windshield is part of the vehicles overall structural rigidity and design, same as the rear to a point, and not a point to cut corners in any way.
