Rear Leaf Spring Removal
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Repoman2, Oct 16, 2017.
  1. Repoman2
    Repoman2 New Member
    9
    Jul 18, 2017
    I am currently tearing down my '73 and the rear leaf springs and axle have been removed as a one piece assembly. I have all the bolts removed and now I just need to somehow separate the leaf springs from the axle. They are very tight and looks like the rubber bushing is all that is holding them in and I am having trouble getting them apart. I don't want to use a sledge hammer in fear of breaking the leafs, I want to keep them in tacked to use for a roller when I get that far.
    Any suggestions on how to get them apart, thanks.
  2. CorkyE
    10,683
    601
    If you have the U bolts and T bolts out, should be able to work a pry bar between the spring and axle pad. Or, you can use a dead blow hammer.
  3. Bandit723
    Bandit723 Veteran Member
    3,259
    483
    Oct 1, 2016
    Waupaca WI
    Good how to video...
  4. NoneToPass
    NoneToPass Veteran Member
    1,011
    Jan 4, 2000
    Columbus, Ohio, USA
    I just did the same thing (although my springs were already trashed). BP Blaster all around the spring/pad contact. It'll get sucked up like crazy. Then I gently used a wonder bar and they came apart easily.
  5. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    If you break a spring with a hammer it was bad to begin with. Spring shops regularly put the curve in them in the first place by beating on them with a big sledge.
  6. Repoman2
    Repoman2 New Member
    9
    Jul 18, 2017
    I got them apart and one side was already broke, thanks.
