Rear Speaker Suggestions Please
Discussion in 'Car Audio, Electronics & Security' started by Greg73Z28, Dec 19, 2012.
  1. Greg73Z28
    Greg73Z28 Veteran Member Lifetime Gold Member
    210
    Apr 14, 2009
    Joplin, Missouri
    Got the 73 back from paint and have started to put the interior back in the car. One of the things I have decided to do is put the factory rear speaker grilles in the car with some undermount 6 X 9's. The clearance between the right speaker and the full sized spare is tight, so I was wondering if anybody had a recommendation on a speaker that will fit. I am running a 75 watt per channel amp RMS, so they will need to handle some power, but not a ton. What have you guys used?
    Thanks in advance.
    Greg
  2. Lrader99
    Lrader99 Veteran Member Lifetime Gold Member
    894
    Sep 18, 2005
    NW Georgia
    If height is your main concern I would go to crutchfield, sonicelectronix or some similar site and compare 6x9 dimensional specifications.
    IMO 75W RMS is not a lot of power. I have 250W RMS going to 4 channels. Everything is crisp and clear with low gain. Frankly I would like a little more power for the rears but it just won't happen.
  3. Greg73Z28
    210
    Apr 14, 2009
    Joplin, Missouri
    Let me clarify, the amp I am using right now is a 300W, 4 channel amp. It is an older model amp and fairly large. I am planning to upgrade to a smaller JL amp, but stay in the 75 - 80W RMS range. Like you, I would like more to the back, but no real need without hooking up a sub. The idea here is to keep everything hidden and stock appearance.
  4. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
  5. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
  6. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    I like the kenwood 4 way 6x9s or any 4 way 6x9s for that matter. To me they sound better. I also really like the MB quarts speakers
    Michael
  7. AJ_72
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    That's irrelevant when looking at speakers, in reality. Especially full range.
    That's a spec given at 1,000Hz. A 2" $2 speaker can be efficient at that frequency.
  8. Z28zz383
    Z28zz383 Veteran Member
    839
    15
    May 11, 2012
    Florida
    Got the JBL 6x9's 3 ways I believe, Sound real good but hang pretty deep. May work if you surface mount them above the panel instead of below it. $200 bucks and fills the car with sound. Kenwood head unit w200 watts.... No amp...
  9. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    I have the GTO series JBLs in mine
  10. CDesperado
    3,664
    98
    Oct 1, 2004
    Dallas Texas
    Which ones are you referring to?
