Rear Suspension lower on one side
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by newt, Sep 11, 2017.
  1. newt
    newt Veteran Member
    266
    Apr 10, 2011
    South Brunswick, NJ
    After getting the car on the road and driving it around it looks like the driver side rear dropped about 1/2". All the suspension is new front and back. Could the rear leaf spring be binding on the driver side? How could I check? What is the normal distance from the bottom of the rear wheel opening/lip to the center of the wheel in inches?
    Also, i used polyurethane bushings....really squeaky! Any good spray out there to quiet them down even if it's temporary?
  2. ErikNORCAL
    ErikNORCAL Veteran Member
    1,173
    14
    Aug 6, 2003
    now in VA
    It's possible the opposite side is binding. Loosen everything up while on the ground and re tighten
  3. Gary S
    23,992
    1,548
    If you used rubber bushings, there really is no point for the springs to bind. If you used urethane, binding is more likely. Loosening and retightening the high side might tell you something.
  4. BonzoHansen
    20,806
    1,834
    Jun 1, 2005
    Scott from Hamilton, NJ
    1/2" is more or less normal. loosen all 6 leaf bolts, put it on the ground, bounce it a bunch, re-measure. i bet nothing changes. then re-tighten everything while its on the ground.
  5. 71 rs BBC
    71 rs BBC Veteran Member
    477
    65
    Nov 28, 2016
    Indy
    I replaced my body bushings with solid aluminum. My right rear sat lower. It was actually in the passenger side body mount at the firewall. I wrecked it in the 80s (sat in the barn after that for years) and that mount was bent. I basically shimmed it, I think about 3/8". I made a new puck for that spot. Now it sits within a 1/8" at all 4 corners.
  6. Bandit723
    Bandit723 Veteran Member
    3,655
    674
    Oct 1, 2016
    Waupaca WI
    My first question is did this thing sit level before the swap?
  7. 71 rs BBC
    477
    65
    Nov 28, 2016
    Indy
    If you're asking me. It did before I stuffed it into the back of an impala. I basically parked it after that.
