Rear suspension upgrade\spring rates
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Bruce1968, Sep 11, 2021.
  1. tomsti
    tomsti Veteran Member
    1,211
    Jul 15, 2003
    Redmond, Wa, USA
    Thanks, looks like a couple tests are in order. :)
    Any idea how to get a baseline of what stock spring height would be? Meaning if I have worn out springs I can confirm if they are bad through the test above. Do OEM springs sag or do they just lose their rigidity and stay OEM height?
  2. Lowend
    16,630
    1,356
    Mar 25, 1999
    San Jose, CA, USA
    OEM springs sag, the spring rate never changes unless the springs are damaged.
    Here's the problem with ride height: You could've taken 10 brand-new 1968 Camaro's at the factory optioned the same, and they'd all have different ride heights. QC just wasn't that good. This was true of pretty much every car of the era
  3. G72Zed
    G72Zed Veteran Member
    3,499
    1,915
    Sep 8, 2015
    I agree with Lowend on the spring sagging, and the OEM stacking tolerances and variances from car to car.
    But I'm not 100% on the rate not changing if not broken. If the car sags after the years, and it rear weight is the same, it means the springs can't hold up the car as it did originally, so, it's rate has changed and lowered.
    I treat leaf springs almost like valve springs, the need to be measured for "installed" rate and over the nose, they get weak as well, and believe they do loose there rate, perhaps not enough to notice, and it can takes many years.
  4. 81Z28LS
    81Z28LS Member
    56
    14
    Dec 16, 2018
    Hey Biker, what is the Hotchkiss part number for those springs? Also, what shocks and what wheel/tire size?
    I was planning on buying PTFB Springs but haven't found recent posts with feedback from actual users.
  5. roadrace2
    roadrace2 Veteran Member
    1,829
    142
    Jan 13, 2000
    Earth......?
    One thing to also consider are the bushings you choose on the leaf spring eye and rear shackle.
    I used del-a-lum on all 3 points - this seemed to have given me way too much oversteer.
    I went to a rubber spring eye bushing with lower rubber bushing for the rear spring eyelet and a del-a-lum bushing to where it connects to the frame - this is a kit I purchased from a vendor here - this took away some of the understeer - but like others mentioned - rim width, tire and tire pressures also play a major role.
    I've seen spherical bearings installed at the front spring eye and rear shackle area - Global West sells them - I have no personal experience with them.
    Please correct me if I'm wrong - this is based on personal experience.
  6. biker
    biker Veteran Member
    4,363
    2,155
    Dec 7, 2014
    Part number for my rear springs is Hotchkis 2408C. Wheels are aluminum 15x8 Ridler 650 with Cooper 235/60-15 tires.
    81Z28LS likes this.
  7. G72Zed
    3,499
    1,915
    Sep 8, 2015
    Roadrace2 is correct with his post above, the bushing design has a major impact on handling characteristics after the shocks/springs.
    Snap oversteer from binding and induced uncontrol rate is not what you want for a nice predictable ride.
    I use spherical bushings in the front, Del-A-Lum in both locations in the rear. Never solid in the front, I would use new rubber before in front if not spherical.
  8. landpilot
    landpilot Member Lifetime Gold Member
    42
    Oct 2, 2013
    Louisville, KY
    +1 on this… I use Global West reverse -2 springs with spherical bushings in the front and del-a-lum in the rear, along with Viking double adjustable shocks. It’s a great combo and allows the rear end to track better through the corners. I don’t know if GW is selling any springs right now due to supply issues, but they might have the bushings.
  9. biker
    4,363
    2,155
    Dec 7, 2014
    I really like the idea of the spherical bushings, and may do that upgrade if I can find them.
  10. landpilot
    42
    Oct 2, 2013
    Louisville, KY
    Here’s a link to the kit ($419) on GW’s website…. https://www.globalwest.net/camaro-f...g-cat5-1967-68-69-70-71-72-73-74-75-76-7.html
    I have the GW CAT 5 springs, they have del-a-alum upper and spherical lower bushings in the rear eye, and spherical bushings in the front eye, just like in this kit.
    The kit takes a special tool to insert the spherical bushings.
    roadrace2 likes this.
