StrongSurvivor
Hi Everyone,
I have done a great deal of research on this topic, but I am still unclear on the subject of stuffing a 12" wide tire and 10" wide wheel under a 2nd gen Camaro. From what I've read, the "safe" setup with a 15" wheel, is an 8" width with 4.5" backspacing and a 275/60-15 tire. This seems to be the ticket for no rubbing with no modifications to shock mounts, springs, or fender lips. Still, there are those running tire widths of 295, 305 and even 325 on 9" and 10" wide wheels, and they don't rub, or at least they rub very little.
The information presented is incomplete and so I am left to assume some things. I would assume that to run something larger than a 275, you must do one or all of the following:
Use a wheel with 5.5" backspacing, relocate the shocks, move the rear springs inboard, remove the exhaust pipes over the rear axle, hammer the seat belt bumps in the rear wells, roll or cut the wheel lips.
I would like to run 28x12-15 tire, roughly a 305/55-15 on a 9" or 10" wide wheel, I assume with 5.5" of backspace, but it is unclear to me what modifications are necessary to run this combination?
For those of you running this setup or something similiar, how did you do it? What did you have to move, or modify, or roll, or beat on, to make it happen?
Your comments are greatly appreciated.
