Rear window channel repairs
Discussion in 'Body Restoration' started by redhouse53, Mar 27, 2020.
  1. redhouse53
    redhouse53 New Member
    Apr 29, 2019
    Hi, I have the rear window out of my '78 and need to a couple of small repairs. What I'm unsure of is what people do about the little trim clip pegs? I can avoid most but one or two are on bits I need to replace. 91003292_700306134040245_6151129776238100480_n.jpg
  2. twestrup
    twestrup Veteran Member Lifetime Gold Member
    212
    102
    Aug 22, 2018
    St. George, Utah
    Just use screws, you can get them when you buy new clips. They come with sealer on them.
  3. Twisted_Metal
    27,555
    1,248
  4. BigBlock73
    2,094
    71
    Jul 10, 2002
    Accord,New York
    I've used the screw in kind.
    In new sheet metal they work very well.
  5. NOT A TA
    NOT A TA Veteran Member
    283
    117
    Feb 12, 2009
    Delray Beach Florida
    I use weld on ones and have used the screw in ones in the past. While the weld on ones are better IMO the reality is that most of these cars aren't put outside 24/7 after rebuild so the screw in ones will probably last a very long time.
    krabben1 likes this.
  6. redhouse53
    Apr 29, 2019
    I like the idea of weld in ones. especially as I'm in the UK, it's wet and I tend to drive the car a lot! Do you have a link?
    Thanks for your help with this, I'm more used to working on European cars so this is new territory for me
  7. krabben1
    8,221
    64
    May 16, 2007
    ( . Y . )Delco
  8. SPG
    SPG Bumblebee Builder
    570
    151
    Sep 1, 2018
    Sacramento
  9. krabben1
    8,221
    64
    May 16, 2007
    ( . Y . )Delco
    If you needed it,you could prolly have the guy that does your welding make it work.
  10. NOT A TA
    283
    117
    Feb 12, 2009
    No link but here's pics of the ones I have, purchased long ago.
