Rear window moulding plastic insulators?
Discussion in 'Body Restoration' started by Da_Raabi, Apr 1, 2021.
  1. COPO
    21,040
    2,581
    Yes, don’t ever remove them.
  2. Da_Raabi
    Da_Raabi Veteran Member
    1,283
    241
    Jan 19, 2011
    Daytona Beach, FL
    The blocks are there, and alignment front to back is fine, it's left to right that's way off. It's sitting on the clips on the pass side.
    It obviously must have been leaking at one point too. There's a ton of very old clear silicone on the pass side. Seems somebody tried to seal it up. The result is that the clips on that side are BURIED while the ones on the driver's side are floating in the wind and the trim won't sit down on the glass.
  3. COPO
    21,040
    2,581
    If it’s butyl then you should be able to leave it out in the sun and then using 2 large glass suction cups in both hands, slide the glass over.
