Rearend Suggestions
Discussion in 'Transmission & Driveline Topics' started by tskills10, May 25, 2015.
  1. tskills10
    tskills10 Veteran Member
    210
    Dec 1, 2007
    painesville, OH
    I am planning on doing some upgrades in the near future and I'm looking for some suggestions. I am thinking of upgrading the differential from a stock unit. I currently am running a 3.42 with a stoke limited-slip out of a 76 Camaro. So any suggestions on something that is street/ strip differential, i.e. Auburn, Eaton, Detroit, powertrax? Also was thinking about C-clip eliminators, but all the ones I've looked at have said "drag race only". Can these not be used on the street and if they are what happens? I will be installing a new stroker in the fall/winter and should be in the 500-600 hp range.
  2. Gary S
    24,213
    1,692
    The factory limited slip basically as good as a new Eaton, and much better than a new Auburn. Consider just keeping what you have in the car.
    Changing it isn't really an upgrade. If you switch to an Auburn, it will be a downgrade.
  3. big gear head
    big gear head Veteran Member
    6,443
    186
    Jul 30, 2001
    Ky.
    The 8.5 Camaro rear end has 28 spline axles. At your claimed HP level I would recommend upgrading to 30 spline axles. Moser and Dutchman make direct replacement 30 spline axles for the Camaro 8.5 rear end.
    You will need a 30 spline differential to go with it. The Auburn is junk and should be avoided. The Eaton Posi and Yukon Dura Grip are probably the best. If it will be drag raced a lot then consider the Detroit Locker. The locker will work much better for burnouts and isn't going to slip any on the line.
    Most c clip eliminators are for drag race only. The tend to leak oil all over your brakes when used on the street, and the small axle bearings are not designed for side loads. It's best to keep the c clips for a street car, or upgrade to a set of Moser 7900 housing ends with new axles with press on 9 inch Ford axle bearings.
    Hang on to that stock limited slip unit. They are getting hard to find and they work great for lower powered cars that still have 28 spline axles. New clutches are available for them, so a rebuild isn't a problem.
  4. Camaro-Chevelle
    Camaro-Chevelle Veteran Member Lifetime Gold Member
    227
    Sep 22, 2007
    Long Island, New York
  5. tskills10
    210
    Dec 1, 2007
    painesville, OH
    Thanks for the advise on the Auburn unit. I would like to upgrade the to a 30 spline axle. So if I keep this axle unit I'll look at the Eaton or the Detroit Diffs. I also came to a thought about another project that I have. I have a 9 inch sitting in my old S10 project. I may take some measurements and see what it will take to fit that into the Camaro. Decisions, decisions!!
  6. badazz81z28
    21,301
    1,540
    Alabama
    My advice would be to spend the money right. It will be more money, but darn worth it
    Moser built 12 bolt or 9", both will have welded axle tubes, bolted in axles, super strong and choice of differential
    I made the mistake of building g up my 10 bolt...strong but still much to be desired
  7. big gear head
    6,443
    186
    Jul 30, 2001
    Ky.
    If the 9 inch has been cut to fit the S10 then it will be way to narrow for the Camaro.
  8. Zspoiler
    Zspoiler Veteran Member
    4,158
    501
    May 6, 2012
    Federal Way, Washington
    I have my original 8.5 Ten bolt upgraded with a Moroso "Brute Strength" center section with 30 spline Mosier axles ,and Baer Brakes PBR 12" disc brakes. On my 1979 Z-28 RS Pro-Touring car with a 500 HP plus supercharged small block Chevy.Super T-10 four speed and never had a problem.
  9. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    I pieced together a 9" rear end. Housing from a 72 mustang, N center from a truck, Detroit Locker, Ford Perf gears, Strange Pro axles...soon to be disk brakes.
    Doing it again, I'd call Moser, Strange, or M.W. and tell them to send me a rig all done.
  10. tskills10
    210
    Dec 1, 2007
    painesville, OH
    The 9 inch has not been cut. If I recall, when I did the install it was about 3 inches wider than the stock S10 rear. I gotta make some time to dig the truck out and climb around to measure the rear. It may not work, but at this point I'm playing with options.
    ZS10; Doing it again, I'd call Moser, Strange, or M.W. and tell them to send me a rig all done.
    Yea, I'd like to go that route, but I just don't have the upfront money to do that.
