Raindem
I've got a couple hundred miles on my rebuilt 305. Did all the disassembly/assembly myself. Had it machined .030 over at the local shop. Stock crank, new pistons, mild cam, no other mods. Up until now it had been running pretty good. Yesterday I went for a short drive and I noticed on deceleration I'd get a little puff of smoke out the tailpipe. No big deal, I figured, just needs to be driven more.
Well, I was idling it today in my shop while checking the ATF level. All of a sudden huge clouds, and I mean HUGE, of blue smoke start bellowing out the back. There was no odor and no change in how the engine ran. So I shut it down for awhile and started it back up and the same thing happened. Except now the smoke emits immediately upon startup and does not stop. If I rev the engine it comes out even thicker.
I know I have to tear back into the engine, which I'll start tomorrow. But I'd like some ideas on what to look for before I start. The first thing that comes to mind are valve stem seals. The reason I say that is that I didn't really understand how the ones that came with my rebuild kit worked. They sent me 2 different kinds of bell shaped seals and I wasn't sure which ones to use, if any, so I ordered a set of the OEM o-ring style. Still not sure if I even put them on right. My heads are OEM and are not machined for those special seals.
So besides valve stem seals and the obvious blown head gasket, what else could cause bellowing blue smoke?
Thanks
Curt
Thanks
Curt
