cmonson
They can. Take it off and look at the gasket.
BUSHY 409 said:I going to say rings do to any # of things crome rings , not honed right , wronge ring set , did you clean the ring leads ,up side down rings ,did you scuff the bores with 400 grit >> it is not going to fix itself i would poll it and tare it down before you hurt something like a braking ring wicken the bore up wrong thickness rings turning sideways in ring leads OR JUST THINK OF ALL THEM LITTLE SPRINGEY THINKS FROM THE SEALS GETTING ALL GROUND UP & MAKING 1000'S OF PASSIS THRO THE MILL IN THE OIL ...
global warmer said:take the intake manifold off and check your gaskets. I believe you are pulling oil into the cylinders at that gasket
