Recommendation for all round disc brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by simso, Jan 12, 2021.
  1. simso
    simso Veteran Member
    534
    83
    Jul 10, 1999
    Australia Perth WA
    Folks,
    perusing ebay, and all other online stores, who and what brand is a good choice for supplying a complete front and rear disc brake package, that is, master cylinder, slave cylinder, wheel calipers, pads, cables and rotors etc basically a conversion kit to take mine from original to 4 functional discs
  2. Fbird
    5,123
    1,230
    Feb 12, 2011
    atlanta, ga
    Ka-Ching...step 1
    HOW MUCH $$$$$ do you have?
    2. How much work can YOU do?
    3. How big are your wheels
    I'm sure you could call Stainless steel brakes and write a check...be done, or Baer, willwood...etc
    So.....how big are your wheels? how much do you WANT to spend...then we/others can give you an idea how fast your going to stop.
  3. dave@ztech
    4,540
    1,024
    Mar 27, 2016
    NY
    Exactly what FBird said, need a little information, and then the suggestions can roll in , look at CPP to have completed kits at the lowest price and Stoptech , I think at the other end , and then you also need to provide, what you plan on doing with the car , track star? Auto crossing? Drag , all have different brake requirements. This is a fun part that needs to be thought out well. I
  4. simso
    534
    83
    Jul 10, 1999
    Australia Perth WA
    Well first its all got to be done by me as its got to be shipped internationally to australia.
    This is for my weekend driver, Engine is a 383 efi. Wheels are just ss cragar 15x10's on the rear,
    No racing or any of that sort of stuff, car leaves next week to go back to the paint shop, so i can order whatevers needed and have them waiting when it comes back.
  5. dave@ztech
    4,540
    1,024
    Mar 27, 2016
    NY
    Keeping the 15 inch rims will limit your choices, I would check CPP , they have a complete kit , call or email them for some suggestions
  6. CorkyE
    11,109
    789
    Having gone down the same road, and if you're keeping the 15" wheel setup, your bang for the buck is quality oem replacement parts. There's nothing wrong with the disc/drum setup you have now.
    NOT A TA likes this.
  7. BonzoHansen
    20,456
    1,641
    Jun 1, 2005
    Scott from Hamilton, NJ
    yeah, under 15s the choices are limited. you could do the 1LE/B-body setup up front for 12" rotors, all you need is spindles, new rotors and wheel bearings. I am not a fan of the 2nd gen firebird/caddy style iron ratchet rear calipers, but that is certainly an option. Companies like Right Stuff sell kits with those kind of calipers.
  8. simso
    534
    83
    Jul 10, 1999
    Australia Perth WA
    Thanks, food for thought
  9. TTR230
    TTR230 Veteran Member
    203
    74
    Aug 1, 2020
    Burlington, Ontario
    I see a few Camaro guys from Australia on here, I think? I thought certain Firebirds (ws6?) Came with disc rear end, didn't they? Can you add a firebird rear-end and related parts to make it work? Provided of course that one can find such an animal being parted out down there.
    I have no idea if that's realistic in the least, just thinking out loud. I had no idea you guys got camaros at all?
  10. Lowend
    15,851
    929
    Mar 25, 1999
    San Jose, CA, USA
    NOT CPP - they are cheap Chinese junk
    With parts availability issues, and needing a single box, I'd be looking at Baer They make some outstanding kits, many of which use Aussie manufactured PBR Calipers (so parts are easy to come by)
    Front
    Rear
    General (stay away from the drop spindles, they are more trouble than they are worth)
    https://baer.com/1970-1981-F-Body-Camaro-FireBird-TransAm-Brakes/
    Wilwood also makes kits for the 2nd gen, I'm not as impressed but it's still good stuff
    https://www.wilwood.com/BrakeKits/B...maro&option=Disc+Brake+Spindle&axle=Front+Kit
    The 15" wheels are the limiting factor here, you just can't fit much under them.
    SPG likes this.
