Remove traction bars or not?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Widzia, Mar 29, 2011.
  1. Widzia
    Widzia Veteran Member
    107
    Nov 17, 2009
    Lithuania, Vilnius
    Hi. There are Traction bars on my Camaro.
    I don't like the way they look, so i want to take them of. Also, i am intended to drop the rear end a bit. My Camaro has up to 250 Hp, so, i suppose, i do not need T.Bars, right?
    Question No.1: What parts do i need now to take the T.Bars off and ride without them?
    Question No.2: How does the ride could change without T.Bars?
    Thank You very much.
    BTW: Sorry for thread, but i could not find the answer in other Traction Bars threads.
  2. 71 Camaro
    71 Camaro Veteran Member
    1,682
    Jan 10, 2007
    Cedartucky
    Wow, Vilnius resident and 2nd gen owner! I am of Lugan descent and have relatives in the capitol city.
    I can't tell much from your pic, but if you mean slapper bars, I like how they look, but doubt it they do much for the ride or handling. If you don't like them, they should just unbolt.
    So hows it feel to have the coolest car in the Baltics?
  3. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    Most of those "slapper" bars replace the spring/shock bracket and used the original "T" bolts" OR "U" bolts to bolt them on. ASSUMING that this is true, all you should need to do is unbolt the "traction bars" and then install the original shock/spring brackets.
  4. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    This is a good idea the traction bars are ugly
  5. Widzia
    107
    Nov 17, 2009
    Lithuania, Vilnius
  6. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    Not that I am aware of
  7. joshp01
    joshp01 Veteran Member
    808
    Aug 20, 2010
    Amarillo, Texas
    I took mine off as soon as I got my car and threw them in the trash :) However I replaced them w caltracs but for a daily driver/cruiser car you would not really need any
  8. Widzia
    107
    Nov 17, 2009
    Lithuania, Vilnius
    I see.
    BTW, there should be rubber pads between the schock plates and Leaf springs. Could I ride without them (Cause i had seen Camaro with no pads)?
    Here is 69' Camaros leaf spring without pads.
    Thanx.
  9. marlin
    marlin Veteran Member
    242
    Oct 27, 2009
    Wantagh, NY
    Take a picture where they are bolted to the leaf spring and I'm sure you will get more exact advice.
  10. retorq
    retorq Veteran Member
    4,921
    May 13, 2003
    Kingman, AZ
    You sure that has no pads?? Looks like there is one there to me.
