removing kickpanel's
Discussion in 'Interior Restoration' started by bowtie1, May 29, 2008.
  1. bowtie1
    bowtie1 Veteran Member
    431
    Jun 13, 2004
    canada
    trying to remove my kick panel,s, to dye them black. Is there a trick to this? started on the passenger side but the vent's go so far into the finder that i'm hitting the heaterbox and the driver's side with the ebreak and such it looks like a realy big job. My friend just did the one's in his son's 79 trans am and he said he did them in car with out removing, is this the way to do them? Thanks for any help.:confused:
  2. 77RS
    77RS Veteran Member Lifetime Gold Member
    2,943
    Oct 18, 2006
    Asheboro, NC
    You're right. The park brake lever and heater box have to come out if you want to remove the kick panels.
  3. bowtie1
    431
    Jun 13, 2004
    canada
    thank you.
  4. Wouldabin
    Wouldabin Veteran Member Lifetime Gold Member
    1,144
    Jul 21, 2005
    Long Island & White Plains
    not a fun job. Mask off the area and try to get er done in the car.
  5. John Wright
    15,169
    388
    Aug 9, 2002
    Rustburg, Va
    also the metal trim up the A pillar either needs to come off or be loosened...I had to take mine completely off to get the panel out from under it.....Also don't forget the e-brake has two nuts underneath the M/C Booster on the firewall...I missed those and wondered why it wasn't loose yet....LOL
  6. protour73
    protour73 Veteran Member Lifetime Gold Member
    6,028
    Sep 21, 2006
    West of Chicago
    parking brake assy. YES............heater box NO......you do not have to remove the heater box to get the pass.side kick panel out. FYI;) at least not on a 73
  7. Keizer
    Keizer BANNED
    7,971
    Jan 17, 2005
    Wa State
    I didn't have to remove my heater box either to get the passenger side out.
    Also, on the drivers side, it helps to remove the dimmer switch assembly.
  8. John Wright
    15,169
    388
    Aug 9, 2002
    Rustburg, Va
    A/C vac can....needs to be taken out on the Pass side kick panel if you have A/C
  9. John Wright
    15,169
    388
    Aug 9, 2002
    Rustburg, Va
    +1...take the switch out.
    edit: Wait...does a 77 have the dimmer on the floor?
  10. BTTB71SS
    BTTB71SS Veteran Member Lifetime Gold Member
    4,797
    May 10, 2006
    Harris, MN
    I would think so because the 78 I have has it on the floor
