removing kickpanel's
Discussion in 'Interior Restoration' started by bowtie1, May 29, 2008.
  1. Damon23
    Damon23 Veteran Member
    2,677
    20
    Jan 29, 2006
    Georgia
    It will be easier to take the time to remove the screws, mask everything off and dye it on the car.
  2. protour73
    protour73 Veteran Member Lifetime Gold Member
    6,028
    Sep 21, 2006
    West of Chicago
    holy crap, dude...............you can't really be serious.....leave them in the car:eek:
    This is not rocket science here, remove the e-brake assembly, a few screws in the kick panels, and maybe the dimmer diconnected
  3. SG71SS
    SG71SS Veteran Member
    1,282
    8
    Dec 16, 2004
    Los Angeles, California
    The heater box does not have to come out. Just pull on the kick panel and lift it up and out so that the baffle door housing can clear the interior sheet metal.
    Unfortunately, on the driver side, the e-brake assembly MUST come out. But it's pretty easy. There are to nuts on the engine-side firewall just below the MC/booster that need to be removed then one bolt and one nut that hold the e-brake assembly in place inside the car. This will allow you to swing away the e-brake assembly enough to remove the rest of the kick panel mounting screws and to remove the panel. I have never had to remove the dimmer. Just manouver the kick panel around it
  4. bowtie1
    bowtie1 Veteran Member
    431
    Jun 13, 2004
    canada
    thanks for all the tips guy's.
  5. pete0331
    pete0331 Veteran Member
    656
    Mar 26, 2006
    Kitsap, WA
    I just removed the kick panel from the passenger side.
    It was being held in by putty. Was this done at the factory?
  6. krabben1
    8,245
    74
    May 16, 2007
    ( . Y . )Delco
    Yeah.And lots of it!
  7. ejpii
    ejpii Veteran Member
    246
    Mar 10, 2008
    Northeast
    Make sure you put that putty back too or you'll have a floor full of water. For years I had this leak on the passenger side in the front. One day when I had my rug out I was washing out the cowl area and noticed water coming in. Put in new putty no more leak whoo hoo.
    EJ
  8. pete0331
    656
    Mar 26, 2006
    Kitsap, WA
    Thanks for telling me, if you didn't say anything I probably wouldn't have.
  9. 77RS
    77RS Veteran Member Lifetime Gold Member
    2,943
    Oct 18, 2006
    Asheboro, NC
    IIRC I had to pull the heater box on my '77 with AC. I was going to pull the box anyway, so I may have decided to just get it out of the way before taking out the passenger kick panel. I still think that the actuator wouldn't clear the sheetmetal without removing the box first though :confused:
  10. protour73
    6,028
    Sep 21, 2006
    West of Chicago
    yea it was done at the factory, and you need to replace it also.........a great replacement can be bought at Home Depot, by all of the weather seal for windows and doors...;)
