Removing the hard seam sealer
Discussion in 'Body Restoration' started by Mr Sunshine, Jan 22, 2018.
  1. Mr Sunshine
    Mr Sunshine Veteran Member
    105
    Dec 12, 2016
    Missouri
    What's the best way to remove the hard white seam sealer between the cowl and the firewall? 20180120_162654.jpg
  2. Smokey15
    Smokey15 Veteran Member
    3,290
    1,366
    Aug 13, 2017
    Caledonia, MI
    I've had to use a sharpened, shortened putty knife. Haven't tried a sharp bladed multi-tool or air chisel, but I'll bet either would work. Or I get close to it with a picture of Rosie ODumbell. That will make anything go soft.
    Coadster32 likes this.
  3. Mr Sunshine
    105
    Dec 12, 2016
    Missouri
    I'm scraping with different hand tools, putty knife and chisels etc. I think I will try a wire wheel next weekend and see how it goes. If it doesn't go well I'll try a picture of Rosie!
  4. budro6968
    budro6968 Veteran Member
    3,678
    671
    Apr 2, 2016
    Jax Florida
    You don't want to want to destroy it with that! LOL. May try a propane torch. heat it and dig it out. Then wire wheel.
  5. Jeep43
    Jeep43 Veteran Member
    1,343
    53
    Mar 30, 1999
    Connecticut
    Wire wheel in a die grinder should clean it out, will get the metal bare too.
  6. Jeep43
    1,343
    53
    Mar 30, 1999
    Connecticut
  7. steins70z28
    steins70z28 Veteran Member
    244
    37
    Apr 14, 2012
    Tulsa, OK
    I've used a 5 way putty knife. Sharp and very stiff and will stand up to a hamm 20180123_075913-1.jpg er. Eye protection and gloves are a must.
  8. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
  9. 1978 Z/28
    1978 Z/28 Veteran Member Gold Member
    151
    60
    Jul 17, 2017
    New Brunswick
    I bought a oscillating tool from harbor freight, sealant just peals away does not become air borne
    https://www.harborfreight.com/power...iable-speed-oscillating-multi-tool-63111.html.
    great for removing ziebart and dried joint filler. I use the 3/8 bi metal blades with teeth in close areas
    https://www.harborfreight.com/power...n-bi-metal-multi-tool-plunge-blade-61810.html
    1 1/8 in bi metal blade with teeth
    https://www.harborfreight.com/power...n-bi-metal-multi-tool-plunge-blade-61812.html
    and rigid scarper
    https://www.harborfreight.com/power...eel-multi-tool-rigid-scraper-blade-61828.html
  10. Mr Sunshine
    105
    Dec 12, 2016
    Missouri
    The $40 HF tool sounds like a good option. I know eastwood also has an electric rotary tool that works good for this and costs $200. And I'm usually the guy that if I need the tool I buy the tool, but it seams like I've been spending more on tools lately that on my car so looking to avoid another high dollar specialty tool.
    So if I torch this stuff will it just burn-off? As hard as it is I can't imagine that it would turn soft again, but I guess I can give it a try, nothing much to lose.
