replaced door latch?
Discussion in 'Body Restoration' started by badslife2, Jun 28, 2014.
  1. badslife2
    badslife2 Veteran Member
    491
    Nov 11, 2001
    Saginaw,MI
    I finally got around to replacing the drivers door latch.
    now that it is done,do I lube it or grease it or something?
  2. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    yes, lightly grease it (white lithium works best but some dry lubes are easier to get into the working parts). It is more easily done with the latch out of the car so lube it before you install your replacement.
  3. hogg
    hogg Veteran Member
    3,190
    30
    Dec 29, 2000
    pegram,tn.,cheatam
    Did it make a lot of differents?
  4. badslife2
    491
    Nov 11, 2001
    Saginaw,MI
    great!
    I should of asked on here before doing this,now I have to take door panel back off.
    ok no biggie!
  5. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    Was it repop latch? I would suspect that they would be shipped lubed to prevent rusting on the shelf. Personally I only ever serviced OE ones which either had gone dry over the years or needed to be thoroughly cleaned and relubed.
  6. badslife2
    491
    Nov 11, 2001
    Saginaw,MI
    yes it was a new latch,bagged up.
    just do not want to ruin this new one.
