Replacing 1/4 panel versus a Patch
Discussion in 'Body Restoration' started by badazz81z28, Feb 26, 2020.
  1. badazz81z28
    19,207
    1,087
    Alabama
    What are the thoughts on this? The passenger 1/4 has some damage, but its right on the body line. When is it ok to just use a patch or is it better to just replace the whole thing?
  2. Twisted_Metal
    28,457
    1,778
    What kind of damage?
    Is there any rust on any of the quarter or its neighboring parts?
    If it's only dented and not rusted... Work it out and keep your original sheet metal.
    IMO, a bit of filler is acceptable if it's done right.
    hubedobeedo likes this.
  3. COPO
    19,619
    1,703
    If your going to use a full aftermarket qtr panel that doesn’t fit, you will curse so your better off to keep as much of the original sheet metal as you can and go with a patch.
  4. Brian
    Brian Veteran Member
    368
    Aug 12, 1999
    OHIO
    I have to agree with COPO, mush easier to adapt discrepancies with just a patch than with a whole quarter.
  5. lapedr
    lapedr Veteran Member Gold Member
    627
    21
    Jan 28, 2003
    Pembroke, GA
    Check the outer wheelhouse and trunk dropoff on the bottom by the drain plug for rust if its allot I would replace the qtr. I was in the same situation and had to replace what I listed bc what I couldn’t see was so bad. I had never done it before but I read allot and did it
  6. Jim Streib
    404
    67
    Apr 6, 2004
    Saint Louis, MO USA
    While it depends on where the patch joints will be at, if you are not worried about how it looks on the inside with seeing these seams, then great, but it might also throw up a flag to someone wondering how well other things might or might not have been done.
    Yep, what you might see on the outside could only be the tip of something worse that's hiding.
    Jim
  7. xten
    xten Veteran Member
    3,799
    2,638
    Sep 24, 2014
    Pittsburgh, Pa.
    Put up some pics so we know what kind of damage you're talking about
