Replacing door handle
Discussion in '1978 - 1981 Specific' started by Lizzard323, Oct 7, 2019.
  1. Lizzard323
    Lizzard323 New Member
    9
    Jul 31, 2019
    Nothing is easy ever....geeze.
    So, left door handle broken. Bought new one. Got door panel off. I see ONE nut holding the door handle on and the other one is tucked behind some metal, cant even see it.
    What am I missing? Do I need to take the window out?
    Help.
    Eddie
  2. 80sz
    80sz Veteran Member
    3,733
    633
    Feb 2, 2014
    Buffalo,n.y.
    Yes window needs to come out. You might be able to remove stop on window track and crank up higher and get room but it’s tight.
    buick skylark likes this.
  3. Twisted_Metal
    28,824
    2,003
    If you remove the interior panel, you can loosen the window stop at the bottom of the door and lower the window enough to access the two nuts.
    I know I managed to do this without removing the window but it was over 30 years ago so I don’t remember much for details.
  4. turbobuick
    turbobuick Veteran Member
    192
    42
    Nov 24, 2018
    I did this last year. It was really tight I used a long extension and swivel but I got the second bolt out without removing window.
  5. Lizzard323
    9
    Jul 31, 2019
    If it ever stops raining here I will try again. I thank y'all.
  6. TommyRS70
    TommyRS70 Veteran Member
    1,338
    187
    Jan 31, 2004
    KY
    1/4 inch drive set with extension/ swivel might be easiest to weasel in the tight spot.
    turbobuick likes this.
  7. 74Z28GC3
    74Z28GC3 Veteran Member
    1,810
    78
    Sep 1, 2000
    North Pole, Alaska
    Hopefully, this video should help you to remove and replace your door handle.
    [email protected] likes this.
  8. TommyRS70
    1,338
    187
    Jan 31, 2004
    KY
    " One-nutted it"! Best part!!!
  9. Lizzard323
    9
    Jul 31, 2019
    Got it in. Thx guys....
  10. severum17
    severum17 New Member
    29
    Sep 5, 2001
    South of Dallas TX
    I removed both outside handles without loosening or removing the windows.
    You can do it.
