Repop floor pan alignment for 70
Discussion in 'Body Restoration' started by Earlsfat, Dec 12, 2020.
  1. Earlsfat
    Earlsfat Veteran Member Lifetime Gold Member
    1,552
    19
    Jun 14, 2006
    Whut?
    Trying to replace a piece of a driver side floor pan, the original was swiss cheese with a couple 3 inch holes by the foot well. It bent when removing it, so i can't really compare it to the repop one.
    I think the repop one pretty different than the original Because it WILL NOT line up. At all. Any one run into this problem?
    At this point i think I'm going to beat the snot out of it until it fits, but it's going to be UGLY.
    Also the trans tunnel has creases in it that i don't recall seeing on other guys cars. Wondering if this thing has been in a wreck and maybe that's why it won't line up.
  2. xten
    xten Veteran Member
    4,016
    2,988
    Sep 24, 2014
    Pittsburgh, Pa.
    Hey Jim, looks to me that those creases look too deliberate and stamped out on the tunnel to be from a wreck. I don't remember seeing them on my 73, (memory sucks) but wasn't really looking for them either.
    Is it too wide? is that what's keeping it off the floor? I was wondering what year you have and if your panel may have been tagged wrong, as the floors changed at one point. Think it might have been 75 for cat.
  3. badazz81z28
    20,392
    1,337
    Alabama
    The creases are made by the stamping process, my car has them too
  4. Earlsfat
    1,552
    19
    Jun 14, 2006
    Whut?
    Thanks for the reply, I've been looking at other people's progress reds and don't recall seeing them either. But they do kinda look intentional.
    It looks like the whole thing is just too small, it had lips all around it that weren't on the original sheet metal, so I smashed the lips out and it fits a lot better. Nothing seems to want to lineup though, for instance If you line up the hump where the parking brake cable goes through the floor pan, The 2 indentations on the transmission tunnel will be off By about 3/4 of an inch. And the bend at the top part of the panel seems to be way too sharp, Show where the top of the panel should meet the fire wall is about an inch short of actually touching the firewall.
    I think I'm just gonna smash the thing in there and get this thing back on the street, maybe a year so down the road have somebody replace the whole floor Pan With a complete piece.
  5. COPO
    20,605
    2,315
    S/B no creases in the driveshaft tunnel for 70.
  6. steins70z28
    steins70z28 Veteran Member
    312
    51
    Apr 14, 2012
    Tulsa, OK
    My original floor pan in my 70 has virtually the same wrinkles with no signs of damage anywhere on the body of the car. 20201213_170326.jpg 20201213_170335.jpg
  7. Green hornet
    Green hornet Veteran Member
    2,014
    466
    Oct 11, 2015
    North Bay, CA
    Here is a photo of my 70 floor pan when I installed a four speed. I have the same wrinkles, it’s the original floor pan.
  8. lapedr
    lapedr Veteran Member Gold Member
    666
    23
    Jan 28, 2003
    Pembroke, GA
  9. 70lt1z28
    4,222
    967
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Yeah, mine had wrinkles too, especially at the shifter area. I bought the same panel as lapedr and carefully cut and fit. I did notice that the "X" bead size was different on the AMD panel than my 1970 original was. I sectioned around it to save the original.
  10. lapedr
    666
    23
    Jan 28, 2003
    Pembroke, GA
    Yep I did the same thing I took it to the brace under the floor pan and used sheet metal screws to hold it in place as I plug welded around the edges, I chose not to stitch bc im not so good at preventing burn through im still a beginner, good job 70lt1z28
