Reproduction leaf spring mounts?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by biker, Jun 15, 2021.
  1. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    Don't even go there.....:confused:
  2. Fbird
    5,605
    1,549
    Feb 12, 2011
    atlanta, ga
    SFC are a win win win situation....BUT as you know there are many ways to tackle that. I would assume your body bushings are solids? The HERB mod is pretty straight forward CUTTING stuff out of the way...with expected lowering of about 3/8" (at the wheel)IIRC
  3. biker
    biker Veteran Member
    3,556
    1,625
    Dec 7, 2014
    Yes. Global West solid bushings, GW sfc. I bought the repop spring brackets, but before I drill them for the Herb A. mod, i want to see where the car sits with the new springs. I dont want to lower things too far and cause an issue with pinion angle. I'm hoping to end up at either the same height I have now, or even a touch higher.
    I got ambushed by an outboard motor problem, so I'm working on that now. If I dont have a way to my cottage, mama biker will not be happy.
  4. G72Zed
    G72Zed Veteran Member
    2,914
    1,421
    Sep 8, 2015
    FWIW biker, I posted about this HA mod and it's effects on lowering the rear a while back and the complementary rear change to the HA front eye position's .750 up in the pocket is to extend the rear pick up point 1 full inch, it helps to keep the rear height close to the same and adds to the HA anti squat advantage.
  5. biker
    3,556
    1,625
    Dec 7, 2014
    Thanks man! I will look for that post, I'm having a hard time picturing what you are saying.
  6. Fbird
    5,605
    1,549
    Feb 12, 2011
    atlanta, ga
    if you RAISE the leaf mount bolt UP into the car it affectively changes the "instant center" FORWARD 1" relative to the CAR"S center of gravity, giving you "anti-squat" characteristics. 3/4" movement on 18" leaf spring (ish) gives you about 2* pinion change
    G72Zed likes this.
  7. biker
    3,556
    1,625
    Dec 7, 2014
    Ok, thanks, looks like it will take some experimentation to make sure I set it up properly.
  8. G72Zed
    2,914
    1,421
    Sep 8, 2015
    I found it, it was under "driveline angle issue?" here's the info from my reply on post #14.
  9. biker
    3,556
    1,625
    Dec 7, 2014
    Thanks G!!
  10. G72Zed
    2,914
    1,421
    Sep 8, 2015
    My pleasure biker.
