Reproduction rear view mirror for 1970 Camaro.
Discussion in '1970 - 1973 Specific' started by john Gialanella, Jan 3, 2021.
  1. john Gialanella
    john Gialanella Veteran Member
    408
    18
    Oct 15, 2008
    Bloomfield N.J.
    When I bought my 1970 SS 396 Camaro in 2012 it was numbers matching and has almost all the original parts. But the rear view mirror was black padded trim, not grey. I sold that one and bought a reproduction Grey padded rear view mirror. The only problem is that when I slide it over the metal piece glued to the windshield it does not go all the way down. Apparently the width of the metal piece on windshield is a fraction wider then the width of the base of the mirror. I wanted to buy the OER Brand (Company in California) but want to make sure that I do not have the same problem. Did any members buy reproduction rear view mirrors for 1970 Camaro and did it go on correctly. I have had good success with them before. But most repro stuff is junk.
    Thanks John.
  2. Budz
    3,254
    298
    Mar 17, 2002
    Ashburn, Va USA
  3. Twisted_Metal
    29,066
    2,123
    If it’s real close to fitting...
    Maybe you could use a Dremel tool to widen the slot a little bit to get it to fit the windshield piece properly.
    2ndGenCrazy likes this.
  4. COPO
    20,368
    2,163
    I would tape up the glass and use a small file and file down both sides of the windshield mount since it’s real metal and not pot metal that could be on the mirror.
  5. badazz81z28
    20,151
    1,279
    Alabama
    Why not just remove it and install the correct size one?
  6. john Gialanella
    408
    18
    Oct 15, 2008
    Bloomfield N.J.
    badazz81z28.
    I would think that they are glued on so well that you could crack the windshield trying to remove it. I had hoped one member would have bought a reproduction mirror and it slid on with no problem.
  7. john Gialanella
    408
    18
    Oct 15, 2008
    Bloomfield N.J.
    Correct me if I am wrong, but the first design mirrors look like they do not have that metal piece glued to the windshield and the rest slides on it. It looks like you just glue the base to the windshield. If I am correct, then my Car which has the piece glued to the windshield had the 2nd design mirror.
    John.
  8. 70lt1z28
    4,172
    953
    Oct 3, 1999
    Beavercreek, Ohio, USA
    1st design with the two-piece split tube housing had a round metal "foot" glued to the windshield. These are very hard to find (P.S...I'm looking) as they would come loose and droop down. They were replaced in about May I think with the one piece tube housing that had the tombstone shaped metal foot glued to the windshield.
  9. COPO
    20,368
    2,163
    The 1st design is useless trying to keep the 2 balls from drooping no matter how tight you tighten the screws. And this is why I got a mirror from the boneyard just to use the ball that slides onto the windshield.
  10. badazz81z28
    20,151
    1,279
    Alabama
    There is a proper way to remove them. There is a release agent and a cutting wire if I recall...
