Restored Wheels 1972 Z28
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Double J, May 20, 2017.
  1. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    Well what do you guy and gals think..........
    This is the OER paint for 1970-74 Z28 wheels
  2. dadgonebroke
    dadgonebroke Veteran Member
    359
    29
    Jul 1, 2008
    Nature Coast of Florida
    Looks great to me but I'd also like a closer picture.
  3. Turbo70Camaro
    2,138
    116
    Jan 7, 2005
    so cal
    looks great, is this the 2 part paint and clear out of a can?
  4. Double J
    411
    15
    Jan 23, 2008
    Michigan
    Just the paint but it comes with two spray heads, I used the white head to paint all surfaces and the black head to give it the surface texture. I sprayed about 12" away to do this, I think it looks pretty good. Closest I've found, the original lacquer is unavailable in my area.
    The original wheel is very dirty so it appears darker.
    FlaJunkie likes this.
  5. 70lt1z28
    3,953
    871
    Oct 3, 1999
    Beavercreek, Ohio, USA
    They look great.
    On a side note, I was able to just last month buy the Ditzler (PPG) Duracryl lacquer 32961 wheel paint with the suede (texture) additive. This is considered the best matching paint for these wheels. It isn't cheap ($100/pint) but is available, at least in Ohio. I was told that PPG is phasing out acrylic lacquer. Got it from Ohio Auto Kolor.
    OEM code 4074
    Interesting that the can is dated 10/25/2005
    http://www.yenko.net/forum/showthread.php?p=801214#post801214
  6. jbloake
    jbloake Veteran Member
    389
    96
    May 1, 2002
    Atlantic Canada
    Double J your wheels look fine I am sure OER did a lot of research before they put anything in a can In this pic from Yenko.net I find the area under the trim ring lighter than the rest of the rim face Is this the way they were ? I have a rim and it is lighter also , so I was thinking mine was sprayed although I was told it was original
  7. jbloake
    389
    96
    May 1, 2002
    Atlantic Canada
    image.jpg image.jpg image.jpg The yenko 70 on bottom
    1972 above with different color in trim ring area also
    Double J likes this.
  8. BARNFIND
    BARNFIND Veteran Member Lifetime Gold Member
    401
    43
    Oct 20, 2007
    GPS WENT DEAD...LOST
    These are original paint Z wheels I got with my 72 SS when I bought it in 1978. Yes, I still have them.
  9. BARNFIND
    401
    43
    Oct 20, 2007
    I do not remember if all of them are gray or black on the back.
  10. Double J
    411
    15
    Jan 23, 2008
    Michigan
    The bottom picture is the way mine look. The back of the wheel is a lighter shade of gray. I've seen original NOS wheels different shades of gray from year to year. Makes difficult to reproduce a perfect match. The OER paint is close not perfect but close, We'll see how it weathers over time
