Return Fuel Line
Discussion in 'Camaro Questions' started by Codeman71, Jun 14, 2020.
  1. Codeman71
    Codeman71 New Member
    16
    May 12, 2019
    Is it necessary to have the return fuel line? The car no longer has the original carb but instead an Edelbrock 650cfm carb. I was thinking about putting an Edelbrock fuel pump on to match the carb but it doesn’t have a return. Thanks!
  2. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,080
    16
    Sep 22, 2007
    Blind Bay, B.C.
    Not necessary but beneficial, it keeps the supply of fuel cooler. I think you can still get the GM fuel pump with the return on it from GM, AC Delco #40777. AC Delco 40777 Fuel Pump.jpg
    Codeman71 likes this.
  3. BonzoHansen
    19,955
    1,268
    Jun 1, 2005
    Scott from Hamilton, NJ
    there are small body OE style pumps available too like in the later years.
  4. Zspoiler
    Zspoiler Veteran Member
    3,535
    302
    May 6, 2012
    Federal Way, Washington
    I have a supercharged small block chevy in my 1979 Z-28 Camaro .It has a modified Holley 830 vacuum carb ,Holley NASCAR type fuel pump with fuel pressure regulator .I also have a return line off my fuel log .to keep the fuel cooler . GM did certain stuff for a reason .So might as well take advantage of it.And there are ways to use it in a non stock application.
  5. G72Zed
    G72Zed Veteran Member
    1,587
    507
    Sep 8, 2015
    Not necessary, but a return does have benefits in a mechanical setup, that's for sure.
    Incorporating the return and regulator after the carb has additional advantages, many ways to design the return.
  6. Coadster32
    1,819
    200
    Oct 2, 2013
    Milford,CT
    It can help with when you have a heat soaking issue, or a fuel smell issue as well. I put a "T" right at the carb, and "orificed" it back into the return line. They also make in-line fuel filters with a return line nipple on it, (much like the picture of the fuel pump above.)
