Return line or not? for Sniper EFI
Discussion in 'High Tech Retrofits' started by rocket dawg, Jul 23, 2020.
  1. 73 Z
    1,171
    73
    Jun 9, 2007
    Los Angeles, Ca
    Did the same! and both will have the rock shield installed. Ran aluminum tube for awhile, but two 3/8" stock lines ran side by side is the way to go.
  2. Fbird
    5,794
    1,684
    Feb 12, 2011
    atlanta, ga
    Was referring to the original Fbody set-up. If it had a PONTIAC motor in it the return would be on the passenger side while the fuel line is run on the drivers side. Not sure if the CHEVY engined Fbodys fuel feed line is on the drivers side then crosses up front or if it runs down pass side like it's fuel pump.
  3. rocket dawg
    rocket dawg Veteran Member
    485
    60
    May 5, 2015
    Grand Rapids Mi
    Okay, gottcha.
  4. rocket dawg
    485
    60
    May 5, 2015
    Grand Rapids Mi
    So far I received just the gas tank with pump and level sender. The rest should be here today. Tank came with a roll over valve/vent. Where did some of you place it?
  5. rocket dawg
    485
    60
    May 5, 2015
    Grand Rapids Mi
    Update. Everything arrived last week. Tank is powder coated silver, looks nice. I wanted to run the fuel lines back towards the filler spout, around the back side and then up the frame rail to stay away from my transverse muffler thats right in front of the gas tank. This will not work as the lines outside diameter is around 5/8ths inch and this wont allow the tank strap to get close enough to get the bolt in, hoses hit the trunk floor ( very little extra space) Plan "B", they must be routed towards the front. Muffler has a heat shield and the stock lines ran in the same area. Then I checked clearance and the hoses attached to the pump hit the trunk floor. Plan "C" Out comes tank for about the 6th time. I had to bang the trunk floor up with a BFH about a half inch in one area. Anyway tank is in. Today I route the hoses and flush the system. I have to drop the exhaust, drill it and weld in a O2 sensor bung. After that it should go fairly decent. I have to drill a hole in the firewall to get the computer screen in the interior.
  6. giggity
    giggity Veteran Member
    1,612
    407
    Mar 18, 2013
    Pearland, texas
    where did you mount your vent? Im trying to do my homework on whether this should vent under the car or in the trunk.
    Just did my O2 bung too!
  7. Fbird
    5,794
    1,684
    Feb 12, 2011
    atlanta, ga
    Plan "D"...add a 1/4 piece of butyle rubber on top of tank....use 1" longer bolts to straps....just really thick anti-squeek strips ;)
    ran my lines like factory WITH a union connection on driver side where fuel feed line makes almost 180 degree turn to framerail. (to ease future removals..)
  8. 73 Z
    1,171
    73
    Jun 9, 2007
    Los Angeles, Ca
    Definitely not in the trunk! Needs to be exterior.
  9. rocket dawg
    485
    60
    May 5, 2015
    Grand Rapids Mi
    giggity likes this.
  10. rocket dawg
    485
    60
    May 5, 2015
    Grand Rapids Mi
    Vent line routed all the way around the tank on the right side (opposite the fuel lines) and to the back as shown.
    giggity likes this.
