Reverse Lockout Rod 5618
Discussion in 'Swap Meet Section' started by Jarhead1971, Oct 9, 2021.
  1. Jarhead1971
    Jarhead1971 New Member
    Oct 9, 2021
    Looking for reverse lockout rod 5618. Thank you
  2. Twisted_Metal
    30,378
    3,003
    Is 5618 a GM part number or aftermarket?
    What transmission is it for?
  3. Dave Nelson
    Dave Nelson Veteran Member
    5,644
    5,659
    Dec 19, 2003
    Vineland N.J USA
    That would be the lower rod for the Muncie, I believe they are reproduced.
  4. ZsZs
    ZsZs Member
    57
    Jun 6, 2017
    One of the hardest finds out there. I bought an after market one, then a couple of years later found the 5618. You can have the repo for 10.00 plus shipping. Maybe you will have better luck then me, it took me about 4 yrs to find one.
    Jarhead1971 likes this.
  5. twestrup
    twestrup Veteran Member Lifetime Gold Member
    309
    183
    Aug 22, 2018
    St. George, Utah
  6. john Gialanella
    john Gialanella Veteran Member
    491
    33
    Oct 15, 2008
    Bloomfield N.J.
    Both Joey Gray and Bob at Camaro specialties reproduce them. I have had 4 of them thru the years, but sold all of them and they were originals not repro's. But it is getting real hard to find them now.
    John.
  7. mallard
    mallard Veteran Member
    1,538
    490
    Oct 3, 2013
    SK, Canada
    I had been kind of half heartedly looking for one back around 1985 for my '74z28 T10 when I removed the headers and put stock manifolds on. It had been discontinued from GM even that long ago.
  8. 70lt1z28
    4,572
    1,142
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Bought mine 4 years ago from TommyRS70. Maybe he has another. I needed the entire assembly including the bell crank. Paid a fair penny then but they are getting harder to find.
    If you buy a used original, look carefully at the rod ends where the go into the bell crank and the trans link. They wear pretty fast there as they are not usually lubricated.
    The repops at one time were not stamped. Maybe they are now.
    Here is an original stamping:
  9. Jarhead1971
    Oct 9, 2021
    Thank you. Good pics
  10. 70RamAirIII
    70RamAirIII Pontiac-aholic
    91
    28
    Jan 10, 2005
    Calgary, Alberta
    I'm going to bump this thread because I earmarked it a while ago when it showed up in a "recent threads" search I made;
    I actually made a reverse rod for my car in the late 1990's, and patterned it off of one (meaning by the bends and end locations) taken off of a 1974 SD455 Trans Am - so this would have been a ST-10 car.
    I made mine from some donor automatic rods.
    Well over the years I have collected parts, and I just now confirmed that I have a proper 5618 reverse rod - and thanks to this thread I know precisely what it's for - thanks!
    I have another one, which I believe is also another reverse lock out rod;
    It's 4-1/2" shorter than the 5618;
    It has the following number stamped on it: S*3072
    * = the "S" is inside a circle; the circled S is shorter in height than the numbers.
    Can anyone tell me what the correct application or use for this rod is?
