rewire my 71
Discussion in 'Troubleshooting & Diagnosis' started by camaro6662, Jul 24, 2005.
  1. camaro6662
    camaro6662 Veteran Member Lifetime Gold Member
    769
    Feb 29, 2004
    Jackson Ga
    Getting to ready order new wiring front to back for my 71. any pitfalls or other problems when I get to installion part?how long should it take ? Thanks for the help and ideas Greg
  2. RS_SS350
    RS_SS350 Veteran Member
    3,259
    Dec 6, 2002
    S.F. Bay Area, CA (East)
    if you have made no modifications to the original wiring, it should be fairly simple... just route everything exactly the way it is now... shouldn't take you more than a day's work... under the dash will probably be the hardest just getting it routed correctly, and the lack of space... if you have the option of removing some of the dash it will probably be a lot easier...
    if you have made some upgrades, you'll need top make the same upgrades to the new harness (it's easier done before installing)...
    are you getting your harnesses from M&H?
  3. camaro6662
    769
    Feb 29, 2004
    Jackson Ga
    Yes Have you used them?
  4. 1974typelt/z28
    1974typelt/z28 Veteran Member Lifetime Gold Member
    145
    Dec 1, 2004
    N.J.
    I used a replacement engine harness from M&H, I unplugged from the engine side of the fuse block and removed the old one as I put in the new one.
  5. LT1FUN
    LT1FUN Veteran Member Gold Member
    287
    Dec 5, 1999
    Chilliwack B.C. Canada
    M&H makes absolutely perfect wiring harnesses as far as I am concerned (and I'm an Electrician). I replaced every harness in my 1970 Z28. All wiring was the correct length and all connectors were identical to the factory ones. Very easy to install.
    Norm
  6. flybye70ss
    flybye70ss Veteran Member
    920
    33
    Dec 6, 2002
    Allen, TX
    i used painless for my 70. no problems, took me about two days. i soldered every connection and then heatshrinked it.
  7. RS_SS350
    3,259
    Dec 6, 2002
    yes i used M&H and it is truly great stuff!
  8. camaro6662
    769
    Feb 29, 2004
    Jackson Ga
    Thanks everyone
