Ribs (trying something different)
Discussion in 'Bon Appetite - NastyZ Style' started by Cougar125, Nov 9, 2008.
  1. Cougar125
    Cougar125 Veteran Member Lifetime Gold Member
    2,698
    Aug 21, 2005
    Whidbey Island, WA
    Gonna try something with my ribs this time.
    I cut them individually so they are single ribs. Doused them with Worchestershire sauce. Put paprika, garlic salt, cayenne/black pepper on them.
    I think I'm going to cover the pan with foil then back them for a few hours. See how they turn out.
  2. 79camaro2001
    4,784
    May 4, 2003
    Monroeville, PA
    Oh I thought you was going to pull a Mark and break your ribs.
    That sounds good though!
  3. gordonquixote
    3,022
    11
    Jul 18, 2006
    Tallahassee, FL
    Ev, you boil 'em first or go straight to the oven?
  4. rscamaro73
    rscamaro73 Administrator Staff Member
    14,977
    17
    May 30, 1999
    Striking fear and destroying the enemy
    Shoot....shoulda lemme know, as I have a nice BBQ sauce I'd make and send off for you guys to try ;)
  5. Mrs67lemanster
    Mrs67lemanster Veteran Member
    238
    May 31, 2006
    Little Dix, TX
    i boil mine first for a couple hours on 225* then finish off on the grill with bbq sauce. baby backs of course.
  6. K5JMP
    10,216
    11
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    oven?:screwup:
  7. gordonquixote
    3,022
    11
    Jul 18, 2006
    Tallahassee, FL
    My bad, I meant big hot grill with beer on it...<hangs head in shame>.
    :crazy:
  8. rkdemuro
    rkdemuro Veteran Member
    4,481
    Oct 31, 2001
    clifton, New Jersey USA
    Man dont know which i like better- dry rubbed baby backs or BBQ baby backs.. I do know that when I make a dry rub, I use alot of coarse sea salt- it really ramps up the other flavors. I do that and coarse cracked pepper, sweet mesquite rub, ths stuff called Badia BBQ rub, Paprika and a wee bit of coarse ground dry ginger. I dont use brown sugar cause the mesquite has some kind of sweetner in it, think a little brown sugar.
    I dont boil em just on the grill with some hickory chunks and cook on low heat for about 2 hours, then crank it to crust it at the end, I can easily eat 2 18" racks no problem, and BudLime washes it down good.
    Wet BBQ I mix Stubbs and some KC masterpiece, but like all commerical BBQ sauces theyre all too sweet. Stubbs aint but dont have the flavor that KC does so I mix em and they temper each other- I go easy on the salt this time but I fork the ribs to poke small holes all over them then rub down the ribs first with mashed Thai hots hot peppers, the hot oil get in the pores and grill it the same way as the dry. When the whole shebang is done its just right, hot sweet tangy lip smackin
  9. 70modelz28
    70modelz28 Veteran Member
    1,169
    Jan 14, 2004
    Hughes Springs, Tx
    cougar i usually rub mine down with what you did, sometimes add a few more things. a pinch of cayenne is good too. i cook ribs in the oven a lot when i dont feel like messing with my smoker. put them in a dish on 225 till they are done. never have boiled any
  10. finally71z28
    finally71z28 Veteran Member
    325
    Aug 12, 2007
    OAK VIEW, CALIF.
    I season mine and bake , covered in foil, at 300 for 3 hours, then off to the BBQ. Quick sear, then baste with "Sweet Baby Rays". Pull the coals to one side and cook on low heat with occasional basting at turnover time for approx. 40 minutes being careful not to burn. Falling off the bone tender!
    That's it. I'm heading to the market for some ribs!!!!!!!
