Rich plugs
Discussion in 'Engine Topic' started by rhino370, Jan 31, 2021.
  1. CorkyE
    11,313
    877
    Not questioning your post on which plugs are fouling, but that is an odd order for a SBC. Here's a diagram just to verify.
  2. rhino370
    rhino370 Veteran Member
    111
    Oct 18, 2006
    It's not a small block it's a 454
  3. CorkyE
    11,313
    877
    Firing order and cylinder numbering still the same.
  4. rhino370
    111
    Oct 18, 2006
    Yes
  5. rhino370
    111
    Oct 18, 2006
  6. Lowend
    16,395
    1,222
    Mar 25, 1999
    San Jose, CA, USA
    Rhino - no one asked. How do you know the front cylinders are rich? Are you reading the plugs? If so, post up some pictures of them here. There are a few guys who are very good at reading subtleties
    The RPM drop when the fans engage may be an indicator here. I'm wondering if the ignition system isn't getting enough power to properly fire the spark in the cooler cylinders. What are you running for an ignition system now? If you are running an MSD-style box, is it grounded directly to the battery?
  7. rhino370
    111
    Oct 18, 2006
    It's a dui ignition, powered off the battery by relay switch. Will post some pics this weekend
  8. John Wright
    15,215
    401
    Aug 9, 2002
    Rustburg, Va
    Interesting thread.
    sandlapper likes this.
  9. Lowend
    16,395
    1,222
    Mar 25, 1999
    San Jose, CA, USA
    OK - so a DUI is basically an HEI, it doesn't have crazy power demands.
    Still - this feels like a power/ignition issue. Nothing about turning on electric fans should cause an engine to drop RPM.
    Are you running an electric fuel pump?
  10. Cardinal
    8,329
    58
    Jun 22, 2003
    Endicott, NY
    What carburetor? If an Edelbrock, set the float height and drop. They are NOTORIOUS for being WRONG out of the box!
