Richmond S/S Overdrive
Discussion in 'Swap Meet Section' started by Plant Engineer, Aug 26, 2020.
  1. Plant Engineer
    Plant Engineer Veteran Member
    404
    108
    May 17, 2017
    Fort Mill SC
    I have a richmond S/S 5 speed. 2.87 first gear , .77 final. Fresh rebuild with zero miles on it . Long shifter. New performance suncros. Professionally set up and clearanced by Brian at SK transmissions . 500 miles on it before the work. I didnt like the way it shifted before . with bellhousing ( not included ) is the same spline count and length as a TH 400 or late rock crusher. Output shaft included
    $2000 shipped to you conus
    SOLD
  2. xten
    xten Veteran Member
    3,760
    2,593
    Sep 24, 2014
    Pittsburgh, Pa.
    PM sent
  3. dave@ztech
    4,411
    981
    Mar 27, 2016
    NY
    If xten, doesn't bite, I am interested, what about the shifting, did you not like? And do you know if that issue is now fixed?
    Thanks
  4. Plant Engineer
    404
    108
    May 17, 2017
    Fort Mill SC
    The syncros were just set up poorly from the factory originally. I had Brian go through it and upgrade the syncro package and set them up properly. He's the man on these things. Gears were perfect and Ive got receipts and break in instructions from SK. Nothing at all wrong with it Ive just fallen in love with the Richmond Super T10 in there now and don't see much reason to change it.
    dave@ztech and czizza like this.
  5. dave@ztech
    4,411
    981
    Mar 27, 2016
    NY
    One last but to me important question, can you slam shift this? What I mean is race type shift, using clutch , just high rpm?
  6. Plant Engineer
    404
    108
    May 17, 2017
    Fort Mill SC
    Using the clutch yes. I havent tried shifting it like a crash box .
    dave@ztech likes this.
  7. Plant Engineer
    404
    108
    May 17, 2017
    Fort Mill SC
    SOLD
  8. CorkyE
    10,923
    699
    Well, that went quick. :)
  9. djgriff
    djgriff Member
    92
    May 9, 2009
    van nuys , CA
    Just checking to see if any way the deal fell thru? Would take it if it did .
  10. 80sz
    80sz Veteran Member
    3,452
    515
    Feb 2, 2014
    Buffalo,n.y.
    ^Ya me to...
