[email protected] please answer this dashpad question
Discussion in 'Interior Restoration' started by need-for-speed, Sep 7, 2020.
  1. l16pilot
    1,979
    190
    Dec 13, 2004
    Hurlock, MD, USA
    Rick - I was the guy you mentioned building the car for MCACN...and yes, the pad installation turned out very nice. I also want to give you big kudos for taking the time to answer my questions on how to get the dye to stick to the urethane. In today's world, your direct involvement is unusual...but very much appreciated. The "ghost" line was virtually undetectable on my pad and ultimately, not an issue as I sprayed my dash dark green and the line disappeared. My previous experience with aftermarket pads was the OER item...absolutely hands down your item is far superior, so thank you for investing your time and money to produce such a nice product!
  2. need-for-speed
    need-for-speed Veteran Member
    742
    16
    Feb 7, 2003
    Conroe, TX
    Rick, that’s great info. Thanks for the detailed response.
    [email protected] likes this.
  3. need-for-speed
    742
    16
    Feb 7, 2003
    Conroe, TX
    I ordered the new NPD pad a couple of months ago. I probably won’t install until next year when I retire. I’ll do it at the same time I install the vintage air. The quality of the pad appears to be VERY GOOD !
  4. GoldenOne7710
    5,477
    790
    Jun 23, 2004
    Athens, GA
    Good deal. I did the opposite with my AC, since I had already deleted all the AC components under the hood, I continued to delete all the ducts and related parts under the dash. Let us know if you run into any hiccups with the install, when you get around to it. Pretty straightforward, but you never know.
    need-for-speed likes this.
  5. boardog
    boardog Veteran Member
    956
    19
    Dec 8, 2006
    north ga
    i have installed a lot of dashes over the last 25 years. for years the only choice was to find a good used one. they became real expensive due to supply and demand. then oer came out with a repo. it fit terrible and had no inner structure to stiffen it. once the instrument cluster was installed it became part of the inner structure. it took a lot of ingenuity to get it installed. it was so bad i found a way to fix cracked original dashes. the dash npd sells is absolutely the best repo dash pad out there. i have installed around 15 of them and have had no issues whatsoever. i installed one 3 days ago and went in like a charm. if your needing a repo dash the npd dash is without question the best one out there. now if he would only come out with a 2nd gen firebird dash.
  6. camaroz22
    camaroz22 Member
    72
    8
    May 23, 2011
    Arkansas
    I'm having problems with a NPD dash right now, they are sending me a replacement. Would you be willing to look at a couple pic's and give me insight as to what the problem may be? Thanks...
  7. boardog
    956
    19
    Dec 8, 2006
    north ga
    Post some pics of your issue.
  8. camaroz22
    camaroz22 Member
    72
    8
    May 23, 2011
    Arkansas
    I sent them earlier in a PM, they are in your inbox. Had to transfer them from my phone to computer. They just say images on this end. Hopefully they will open for you.
  9. need-for-speed
    742
    16
    Feb 7, 2003
    Conroe, TX
    Any chance we could all see the pics and the issues? I would love a chance to learn from others.
  10. camaroz22
    camaroz22 Member
    72
    8
    May 23, 2011
    Arkansas
    Installed a new OER dash first and couldn't live with the un-even line where it mates up to the metal dash. (I have it for sale) Actually some things I liked about the way it is made, but decided to spring for the best. The lines on the NPD are much better until I got to this point. My windshield is not glued in yet so I pulled it back out to try and massage the metal dash down to close the gap but no luck. NPD is very good to work with and have another pad on the way. I also have some pic's of the OER if anyone's interested, will sell it worth the money. The first pic's are with a new OER bezel, and the last ones are with the old OEM bezel as requested by NPD.
