Chevyforever
Carburetors: | Number | Manufacturer | Trans | Type | Primary Throttle | Secondary Throttle | Primary Venturi | Secondary Venturi | |
17080202 | Rochester | Auto | 4-Bbl | 1.375" | 2.250" | 1.093" |
Did you know that one out of ten quadrajets is an 800 cfm? Thats really cool!These are the specs for the 1980 Z28 Q-Jet w/auto trans. Std. trans carb #17080207 same specs.
Carburetors:Number Manufacturer Trans Type Primary Throttle Secondary Throttle Primary Venturi Secondary Venturi 17080202 Rochester Auto 4-Bbl 1.375" 2.250" 1.093"
Hi Brent! my intake is a regular performer. I didnt check that but I suspect the plunger is too long or the rubber gasket in the plunger came off. What are you thinking of?What intake manifold are you using Frank? The gasket should not be leaking, be careful not to over tighten it. With the float bowl full, can you manually (with engine off) work the throttle and see the accelerator pump squirt?
I'm just thinking that if you used a square bore intake with a spread bore (QJet) carb, you will have gasket issues, and the secondaries won't have room to open.Hi Brent! my intake is a regular performer. I didnt check that but I suspect the plunger is too long or the rubber gasket in the plunger came off. What are you thinking of?
I have a Performer RPM spread bore intake, and it says right on it "RPM QJet". When I switched to a 4150 base carb, I had to use an adapter for it to seal properly. I just can't remember if your intake is a spread bore or not.
