Rocker/lifter tick
Discussion in 'The BS Topic' started by CT1275, Sep 21, 2020.
  1. CT1275
    CT1275 Member
    52
    Nov 24, 2019
    Does anyone think that the rocker arms pinging agaings the inside wall of the valve cover could make the rocker loosen up? I tightened it down last time, took the cover off and the same one was loose. I started the engine with the cover off to make sure it was functioning ok. Looked like it was moving ok, but also the "lifter tick" basically went away. There are still rub marks on the inside of the cover so its definitely hitting.
  2. COPO
    19,475
    1,592
    Swap the nut from another valve and see if the loosening nut goes to the other valve. If the nuts are not new then they will back off unless you have lock nuts.
  3. CT1275
    CT1275 Member
    52
    Nov 24, 2019
    I could try that but they're roller rockers with the center lock screw. Polylocks? Is that right?
  4. Chevyforever
    Chevyforever Veteran Member
    893
    223
    Jan 4, 2011
    The top of each rocker stud should be machined flat so poly lock set screw can do its proper job.
  5. COPO
    19,475
    1,592
    So with lock nuts, it’s really impossible for a nut to back off unless your weak. I would crank the engine with a remote switch and make sure all the rocker arms have full open movement and if they don’t then your cam lobe is wearing.
    Here is what my #3 intake valve looked like in Jun 2013 when I lost that solid lifter lobe. I was pissed cause it was only 8700 miles. I went with a roller cam after this.
  6. Coadster32
    2,044
    266
    Oct 2, 2013
    Milford,CT
    It is possible if they are still rubbing. I had to clear the sides of my valve covers as well. The polylocks shouldn't back out, unless other forces, (hitting valve covers might do it), are acting on them.
    COPO's point is that if you swap the nut with another arm, you watch to see if the problem follows the nut, or stays with the valve. Then you'll know where to further investigate. If it is still rubbing, then you need more clearance regardless of which nut you have on it.
  7. CT1275
    CT1275 Member
    52
    Nov 24, 2019
    Yeah, I'm gonna be grinding today and crossing my fingers.
  8. COPO
    19,475
    1,592
    There are 2 lock nuts you can buy, short and tall.
  9. CT1275
    CT1275 Member
    52
    Nov 24, 2019
    I think they're tall but not sure. They seem to stand out quite a bit. They came with the rockers.
  10. CT1275
    CT1275 Member
    52
    Nov 24, 2019
