Roll control (line lock), Air Fuel meter...
Discussion in 'Swap Meet Section' started by EricsZ28, Mar 20, 2014.
  1. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    Roll control (line lock), Air Fuel meter, Shift knob...
    ***ROLL CONTROL IS SOLD***
    ***A/F METER IS SOLD***
    ***Shift knob added***
    TCI - 861700 Roll Stop kit. Purchased from a board member. Both he and I never installed it. I think he may have mounted it on the firewall, but the threads for the brake line fitting look virgin, and so do the wires. The label is peeling up a bit, but I was just going to peal it off anyways. I'm losing a couple bucks on this, but oh well.
  2. Str8 6
    Str8 6 New Member
    19
    Sep 11, 2005
    Okc Ok
    Pm sent
  3. 1979CamaroTX
    1979CamaroTX Veteran Member
    178
    Oct 10, 2006
    Longview, TX
    I'll take it if he doesn't want it.
  4. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    Edelbrock Air Fuel Meter. I used this narrow band O2 meter for a while. It's a good lean / rich indicator. I have the meter, the used O2 sensor, and the wiring harness. You'll need to buy a new bung for the the O2 sensor (available at summit racing, jegs, etc...).
    The wires were cut when I removed it, so you will need to do some soldering (there is plenty of wire left to do this). Here is the manual:
    http://www.edelbrock.com/automotive_new/misc/tech_center/install/6000/6593.pdf
    -pics removed-
  5. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    PM Returned...
    Edelbrock meter still available.
  6. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    Shift knob from an '80 Z28. The threads are a bit worn, but it never caused an issue. See pics. $20 shipped CONUS.
  7. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
    PM Returned on A/F gauge... SOLD!
