RTV on Timing Cover Gasket
Discussion in 'Troubleshooting & Diagnosis' started by GPN, Jul 13, 2020.
  1. GPN
    GPN Veteran Member
    202
    Oct 5, 2016
    My 1979Z now has a (1989) crate motor. The oil pan was leaking so we removed engine Seems the timing cover casket had RTV sealant. Could that have been the cause of leak? we are trying to decide Wether to put RTV on the timing cover part of the gasket or not. (We are aware of the 4-corner spots)
  2. twestrup
    twestrup Veteran Member Lifetime Gold Member
    267
    135
    Aug 22, 2018
    St. George, Utah
    budro6968 likes this.
  3. COPO
    20,097
    2,011
    I would use the gasket sealer on both sides. Paper will eventually leak without it.
  4. GPN
    GPN Veteran Member
    202
    Oct 5, 2016
    Not paper gasket.....one piece Fel-Pro for lower half........sorry I wasn’t more specific. I’ll send a picture
  5. GPN
    GPN Veteran Member
    202
    Oct 5, 2016
  6. COPO
    20,097
    2,011
    Again, the timing cover gasket is some type of paper. Use sealer on both sides and RTV in the bottom 2 corners of the oil pan or it will leak.
  7. Camaro Tim01
    Camaro Tim01 Veteran Member
    340
    58
    Jun 8, 2020
    Bradenton, Florida
    Back in the day I had a timing cover that leaked, after about 4 times changing the gasket... I finally said screw it, took off the cover, threw out the gasket and placed a 1/4" bead of RTV all around it and put the cover back on, wiped the extra that stuck out.... never leaked again... years later I realized it wasn't the gaskets, the cover was probably bent.... ahh to be young and stupid again LOL
    and yes if your doing the oil pan gasket.... the one piece is the way to go
  8. GPN
    GPN Veteran Member
    202
    Oct 5, 2016
    That’s good color. First thing I did when I removed the oil pan was throw that flimsy piece of crap away & bought a new one
  9. Robert stuart Bell
    Robert stuart Bell Rsb78LT
    69
    13
    Jan 21, 2017
    Been fighting the same issue with my car since the first time I pulled the block, I have the exact same pan and gasket with a cheap chrome timing cover.
    Seems the gasket doesn't like sealing against chrome so I wiped a layer of permatex' right stuff in the channel on the bottom of the timing cover and the lip on the top of the pan, haven't driven it since but after about 10 hours of run time it isn't leaking yet
  10. GPN
    GPN Veteran Member
    202
    Oct 5, 2016
    We ended up reinstalling without RTV with exception of 4 corners. Perfectly dry so far after 150 miles—some high speeds.
    Tnx for your response (and nice looking car)
