running 24v to a starter?
Discussion in 'Competition Camaros' started by 4-71/Z-28, Jan 4, 2008.
  1. 4-71/Z-28
    4-71/Z-28 Veteran Member
    109
    Jul 16, 2005
    LOS LUNAS, NM USA
    i was doing some research on mechanical fuel injection and had noticed people complaining about how hard it is to start a mech injected engine and some people were saying that it helps to run 24v to the starter instead of 12v wich obviuosly helps turn it over faster and in turn helps prime faster. apparently it doesnt really have too much of an effect on the starter itself, but how do you get 24v?
  2. Maliboost
    Maliboost Veteran Member Lifetime Gold Member
    7,185
    May 18, 2001
    two 12 volt batteries in series. just like in a flashlight. its a bitch charging it up though.
    I have 2 friends with mech injection systems & neither have a problem starting thier cars.
    Bob
  3. King Itchy
    King Itchy Veteran Member
    337
    Jun 4, 2007
    Las Vegas, NV
    I had an 85 VW with mech injection. 12V is all I needed.
  4. rscamaro73
    rscamaro73 Administrator Staff Member
    14,972
    16
    May 30, 1999
    Striking fear and destroying the enemy
    Yeah, but that's less than 1/2 the engine they're running :crazy:
  5. Marv D
    10,851
    May 12, 1999
    Devils own training ground,,, aka Arizona
    I wanna know how your going to get 24 to the starter and not toast an ignition box????
  6. camaronut79
    camaronut79 Veteran Member
    1,149
    Nov 11, 2005
    destin area, fl
    me too
  7. TheFly
    TheFly Guest
    most auto stuff is already rated for up to 24v, well 14-24v is what stuff will say. Dunno why its 14-24
    reasoning I heard is the electronic industry pre empted more voltage needs as cars get/got more options. Though the auto industry has got by on 12v longer then they thought. Like drills 16 or 24v cars are in the future.
  8. tqueen
    tqueen Veteran Member
    238
    Sep 18, 2007
    Suffolk, Virginia
    Nothing in mine is rated above 18v and the ignition will shut down at 18v to keep from burning up.
  9. TheFly
    TheFly Guest
    18 is an odd number for that.
  10. 74RAT
    74RAT Veteran Member
    3,400
    Dec 28, 2003
    ft. stockton,tx,usa
    you just wire off one battery. that only gives you 12.6v.
    andy
