S10-Blazer rear disc conversion
Skip Fix
2,220
Katy,Texas
I always thought the C clip elim went on outside the backing plates for drum and the same om the 79-81 bracket as that has the offset for the caliper and rotor to line up with the plate on the axle flange
Tpichevy
524
Boise id
Ok here are pics of the red spacers I'm talking about.....
Tpichevy
524
Boise id
I have another 1970 12 bolt with Mark Williams c-clip eliminators and Mark Williams axles and it looks different.....The c-clip eliminator is on the other side of the brake brackets and the c-clip eliminator is much thicker then then the 12bolt under the car. Is it possible the red things are spacers for some reason?
Tpichevy
524
Boise id
What's strange is I see guys talking about running 17x9.5 with 5.75" BS that tuck tires without roller fenders well I would have to roll fenders for sure! I mocked up an old 1996 corvette wheel that's 17x9.5 with 56mm offset (7.4"bs) with a 1.25" adapter that makes 6.15" BS and it fits easy!! I could probably get away with 6.5"bs. Maybe my axles are spaced out for some reason???
Skip Fix
2,220
Katy,Texas
Teh drum looks the correct placement. The disc bracket is pushed out form the C clip inner part so rotos and caliper are now not in the same plane, but with a floating caliper it might be OK. I would also wonder where the bearing is as generally needs to be in both parts of the C clip parts and the disc bracket separates them.
djorgensen3
960
Peoria, Az
I just got my S10 setup working except for the parking brake. I'll be interested to see what some others have to say but I am thinking E-Stop(electric parking brake).
