sbc-ALUMINIUM HEADS
Hulk_smash
26
Sanford FL
I HAVE A 79 BLOCK AND GOT SOME AFTERMARKET HEADS ALUMINUM AND I HAVE A BIG ASS GAP FROM MY INTAKE TO MY HEADS IM TALKING A 1/4 OF IN INCH HAS ANYONE ELSE HAD THIS PROBLEM AND IF SO HOW DID YOU FIX IT I EVEN TRIED MT OLD INTAKE AND ITS THE SAMETHING DOES ADD UP TO ME AND I SPENT ALOT OF MONEY ON THIS SMALL BLOCK I NEED THIS THING TO RUN
Hulk_smash
26
Sanford FL
THEY WERE AT THE TURKEY RUN SO THEY WERE AFTER MARKET FROM A GUY SHOP SO IM THINKING THATS ITS OFF I CALLED HIM UP AND HE TOLD ME ITS MY INTAKE WHICH IS A RPM EDLEBROCK NA I HAD DOUBLE HUMPS ON THERE RECENTLY AND FIT JUST FINE JUST THESE ALUMINIUM ONES
Jodi
1,118
You can use a Spacer. But first...
Is the gap between the Heads and Intake manifold even through out?
If it's not... more than likely your Cylinder Heads has been angled milled (This is when more material is milled on the Spark plug side of the Cyl Heads.)
If this is the case, either the spacer or the manifold will have to be machined first for proper fitment.
Hulk_smash
26
Sanford FL
Jodi
1,118
It looks like the gap is even on both side.
You will need a spacer with a (correct thickness for your engine)... like the ones below if you want to use that Cylinder Heads.
This one is from Dart... there are other makes too.
I would recommend checking the Distributor installed height after, just to make sure proper Cam and Distributor mesh is okay.
Good Luck!
