SBC in '75 Firebird
Discussion in 'Camaro Questions' started by Fbod76, May 23, 2020.
  1. Fbod76
    Fbod76 New Member
    May 17, 2013
    Griffin,Ga
    Hello
    I'm in the middle of swapping a SBC in my '75 Firebird and I'm just wondering about the fuel line situation. The return line needs to be moved to the passenger side since it runs along the driver side on a Pontiac. Are the sending units/tanks for both Firebird and Camaro the same? If so I was thinking I could just get lines from a Camaro and run them as shown on a diagram. Hope y'all don't mind me asking here. Its basically gonna be a Camaro with bird emblems.. The Pontiac guys kicked me out to this site. Lol. I would just go without a return line but with today's fuel and the Georgia heat, a return line can only help.
  2. tom3
    tom3 Veteran Member
    12,688
    633
    Aug 1, 1999
    ohio
    Should be the same two or three lines, bigger line is supply, others for return and vent. Just run them as needed.
  3. 73 Z
    1,082
    56
    Jun 9, 2007
    Los Angeles, Ca
    Your over thinking it, Its just a motor transplant. keep the fuel lines where they're at, and replumb from your carb or FI to existing fuel lines.
  4. dave@ztech
    4,162
    901
    Mar 27, 2016
    NY
    I thought there was something about the starter being on a different side or was that older ones?
  5. CamaroDoc
    CamaroDoc Veteran Member
    2,167
    214
    Sep 13, 2003
    Skiatook, Okla. 74070
    Pontiac V8 starters are on the driver side but I wouldn't think it would make much difference on fuel line routing..
  6. ggtsvnv
    ggtsvnv Veteran Member
    1,228
    68
    Jun 20, 2002
    Fallon, NV
    Not in 75 but by 77 firebirds in some cases were coming with small block chevys. Maybe 77 bird would have the lines you need.
