sbc or lt1 with TH200-4R
Discussion in 'Transmission & Driveline Topics' started by dutch73camaro, Feb 11, 2020.
  1. dutch73camaro
    dutch73camaro Veteran Member
    192
    49
    Jan 7, 2016
    Beverwijk, Netherlands
    do any of you guys know i can use the stock driveshaft ?
  2. camaro71/holland
    1,494
    196
    Aug 27, 2003
    The Netherlands
    Confusing.... what are you changing, the block or the driveshaft?
    Th200-4r has the same cross member mounting distance as a th400, but almost same total length as a th350 and same spline count/diameter of the output shaft.
  3. Twisted_Metal
    29,683
    2,524
    If you had a th350 before... You can reuse the driveshaft. (48.5" from center to center of the u-joints.)
    The th200-4R uses a different crossmember than the TH350 due to the 200-4R having a longer pan and no removable tail shaft housing which puts the crossmember mounting point farther back on the transmission.
    I don't know if the rear of an LT1 is in the same place as a sbc.
    I guess that would depend on the motor mounts you use.
  4. dutch73camaro
    192
    49
    Jan 7, 2016
    oke thanks.
  5. BonzoHansen
    20,753
    1,813
    Jun 1, 2005
    Scott from Hamilton, NJ
    An LT1 is just a small block assuming we’re talking about one of the 90s versions
