SBC woes.
Discussion in 'Engine Topic' started by Trashman, Mar 20, 2014.
  1. Trashman
    Trashman New Member
    16
    Jan 22, 2012
    Indianapolis, IN
    Ok long time listener first time caller, Im 22 and this is the first engine I have built. I may not have all the puzzle pieces yet to help you guys decode this problem, but hopefully I can narrow down the cause of the source of the problem.
    I have a 387: 2 piece 4 bolt main block, Malhe .040" over forged +5cc pistons that are supposed to give 11:1cr with 64cc heads, Forged Eagle 5.7" rods, Eagle cast Steel crank (3.75"). cant remember what i filed the rings to, I know one was .018". (Went off what a 70-71 hi po corvette 350 had in a old chiltons book. Pistons are .014-15 in the hole.
    Cam is comp cam .460/.460 lift, 110deg lobe separation with 218/218 dur at .050. Cam was previously in engine and properly broke in and has only 5000 miles on it.
    Heads are 76cc World Stock Replacements that were previously on engine. gaskets are .040"
    The valves leaked, but I lapped the valves and they did not leak before I put them back on. Carb is a carter 750 currently and manifold is a edlebrock performer intank . Distributor is a Pertronix flame thrower.
    Rotating assembly were all professionally balanced and sized for factory errors, cylinder walls were honed.
    I have yet to drive the car (still on blocks), Engine starts up and idles. Dad says it runs bad, Lazy throttle response, and blows fuel back out of the carb under load. Did a compression test with a old snap on set and Its design only allowed me to access 3 cylinders. and They were all over; 225, 170, 115. My dad thinks maybe we put the cam in a the Advance or retarded position. I dont know, maybe you guys might have an idea?
  2. fbody_mike
    fbody_mike Veteran Member
    979
    Mar 24, 2009
    San Gabriel Valley, California
    Wow, 225 on one cylinder and 115 on another is bad. How did you set the lash on the rockers?
  3. Trashman
    Trashman New Member
    16
    Jan 22, 2012
    Indianapolis, IN
    Hand tight + 1/2 a turn initially. Then It was running bad and all the pushrods were somehow loose so I tightened them again, maybe half turn again. I probably need to re adjust them before I pull the heads to see if it helps
  4. fbody_mike
    979
    Mar 24, 2009
    By this, did you mean that this is solid lifter, or hydraulic lifter?
  5. Trashman
    Trashman New Member
    16
    Jan 22, 2012
    Indianapolis, IN
    solid, I will get the exact specs this weekend
  6. CamaroGP
    CamaroGP Veteran Member
    691
    90
    Nov 10, 2012
    Summerfield, Florida
  7. fbody_mike
    979
    Mar 24, 2009
    ^1, yes. I think you have some valves being held open, which is why the compression is all over the place, and idle is bad, plus the gas shooting backwards out the carb.
  8. Trashman
    Trashman New Member
    16
    Jan 22, 2012
    Indianapolis, IN
    Alright thanks guys. Ill re-adjust this weekend and see if it helps.
  9. CamaroGP
    691
    90
    Nov 10, 2012
    After adjusting the valves properly I suggest you do a compression check again. Just to make sure you had no valve to piston interference. Don't want any bent valves.
  10. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Loosen all the rockers.
    Tighten each rocker so there is no up down loosness, rotate the crank an 1/8th turn and retighten any loose ones, turn it another 1/8th turn until you have at least 2 revolutions. Now add 1/2 turn to each rocker nut.
    The lash is set and won't need to be messed with again.
