Seat Belts
Discussion in '1970 - 1973 Specific' started by 72silverbullet, Feb 19, 2020.
  1. 72silverbullet
    72silverbullet New Member
    Aug 5, 2019
    I am in search of a female end to my 1972 Camaro retractable seat belts. I can't seem to find any female ends that will work with the original retractable male end. I don't want to have to replace them with regular pull to tighten seat belts. Any info helps. Thanks.
  2. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    That's a tough one. Might try checking with a seat belt restoration company. Some of them have spare parts. Ssnake Oyl is one of the more well know companies but there are others.
    https://www.ssnake-oyl.com/
  3. fvdillon
    fvdillon Veteran Member Lifetime Gold Member
    919
    Jul 16, 2000
    Crete,IL
    Hope you have better luck than I had. This is the 2nd design 72 belts, which are very difficult to find. I needed a rear seat re-tractor. Searched for over 10yrs, every swap meet, junkyards and Carlisle for yrs. Put wtb searches out on all the forums. Finally a member found me just the correct buckle. I had it sewed on another re-tractor that was close to orginal. It's hidden beneath seat, so no one can see it. Jim
  4. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,689
    898
    May 21, 2014
    Hutto, TX
    As far as I know, 72 seat belts are one-year only. The set I have wouldn't interchange with my 73 set. I have a 71 also, so I'm pretty sure 72 is the first year of the "three-point system" (lap male retractor, female buckle, and shoulder all connecting).
    I don't know if the 72 seat belts are Camaro only. I sort of doubt it, but you may want to check other 72 GM vehicles. I used some Caprice shoulder belts that fit in my 71 no problem. I've also seen the large plastic shoulder belt holders that are in my 73Z in a big Buick and got some NOS seat belt warning sensor switches that go under the seat from a Buick website.
    In other words, some of our Camaro parts can be found in other cars.
