Seat cleaning
Matt T
822
Pawtucket, RI, USA
What about cloth?
(For newer cars where they went to these light gray and tan colors that seem to get grimy if you look at them wrong.)
I've used a home carpet cleaner (wet vac with hot water/soap mix), but some of the grime doesn't come out. In fact, when they're dry it seems like some of it was just moved around to make a lighter stain over a larger area.
One of the replies above mentioned Fantastic/409. Another mentioned Shout laundry pre-treat.
Thanks
Ksspeed
Eudora, Ks.
I agree, use either of the "M's", Mothers or Meguires are both great with vinyl, and I've had great luck with fabric and carpet using 409. On the fabric though, it will make a difference on the age and dirt as to spot cleaning or actually needing to use a dry cleaner. Just my two cents. Best of luck.
realtimer
18
Tampa, Florida,USA
I have tried using Megs Apc and Tornador black series and made my work faster and efficient. The dilution I used was 10:1.
