Seat cover replacement?
Discussion in 'Interior Restoration' started by Dave Nelson, Apr 25, 2021.
  1. Dave Nelson
    Dave Nelson Veteran Member
    5,319
    4,595
    Dec 19, 2003
    Vineland N.J USA
    My 70 still has the original black standard seat covers in very good condition. The problem is the foam/filler has gotten to the point where there's not much cushion in the seat buns (my butt knows). Can the covers be removed and new foam installed then put back on or should I bite the bullet and replace the covers also? If I decide to replace the covers and the foam what are some of the better products out there?
    75Maro likes this.
  2. 75Maro
    75Maro Veteran Member
    656
    104
    Mar 31, 2008
    Dallas,Tx
    Covers can be reused. You’ll need new hog rings to put it back together but that’s about it
  3. DrPepper
    DrPepper Veteran Member
    248
    56
    Aug 29, 2017
    Central VA
    I agree, your old covers 'may' be reusable. IMO, you won't know until they are removed. They could be dry rotted to the point that they can't be re-used. I'd buy a new set to have on hand if needed. If you don't use them, you can always return them for a refund.
    I replaced the covers and foam on the buckets of my 81. I used American Cushion Industries foam and it was/is perfect. I didn't record who I bought it from. But I know it was from one of the big aftermarket people.
    Good Luck
    Dave Nelson likes this.
  4. arm2004
    arm2004 Veteran Member
    163
    48
    May 5, 2017
    S.E. Ohio
    If i remeber when i did my 70 seats PUI is the only one that has seat foam for the 1970 seats. They were a good fit alittle thick on the foam had to really pull to get new covers on. That my be good or bad if you save your old ones.
  5. Dave Nelson
    5,319
    4,595
    Dec 19, 2003
    Vineland N.J USA
    Looks like I'll be going with the PUI foam and Legendary covers but must be purchased in sets. I only need one cover if anyone is interested in the extra one let me know.
  6. RickM
    RickM Veteran Member
    668
    133
    Apr 16, 2004
    Gaithersburg, MD
    I think you are making the right move. I just finished my first seat bun using American Cushion foam and PUI vinyl, it was a little tough but if I can do it so can you. Here is a pic of my first attempt it is a front seat bun. Don't be discouraged if there are a few wrinkles, a little steam and then baking in the sun really got rid of most wrinkles. You can do it.
    RickM
    1978 Z/28 and Dave Nelson like this.
  7. Dave Nelson
    5,319
    4,595
    Dec 19, 2003
    Vineland N.J USA
    Spoke to a local upholstery shop today, he's confident he can re-foam the seat using my original cover. Good thing as I spoke to Legendary today and told me they are 25 weeks behind on seat cover orders.
  8. COPO
    21,041
    2,581
    I had mine swapped with the pass side. Just like new again.
  9. Dave Nelson
    5,319
    4,595
    Dec 19, 2003
    Vineland N.J USA
    Did you swap just the covers, and not the foam?
  10. COPO
    21,041
    2,581
    Foam only. Covers are still original custom cloth, but drivers seat cloth cover was done in 1985 and was the only one that had some rips and wear.
