serpentine upgrade, fan almost went through hood. Anyone done this with a flex fan?? pics inside
Discussion in 'The BS Topic' started by QUAKE_WARS, Oct 17, 2020 at 12:08 AM.
  1. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,191
    253
    Dec 19, 2008
    I put this in BS section because this is in my 85 k20 4x4.
    I got tired of the single belts and issues. I put a 1992 trans am single belt serp setup.
    it worked perfect. I put a small electric fan in front of 4 core radiator and truck ran about
    210 to 205. Not good for a SB 350. I spent $93 for a reverse flex fan and 3 1/2 inch spacer.
    I have done this swap at least 15 times with no issues, but only using electric fans.
    The first time I use a flex fan (reverse rotation) at 5600 RPM it blew up!!:mad:
    My question is are these water pumps not suppose to use fans?? as no cars were ever
    equipped with fans on the water pumps, only electric fans!
    Anyone ever done a serpentine swap and used a flex fan with success?
    Here is whats left of it. Fan had 20 minute drive time lol. Pulley broke right
    at the shaft. everything else was just in the way. So much for the 4 core radiator.
    20201016_210244.jpg 20201016_210337.jpg 20201016_210458.jpg 20201016_210620.jpg 20201016_210945.jpg
  2. QUAKE_WARS
    2,191
    253
    Dec 19, 2008
    more 20201016_211018.jpg 20201016_211802.jpg 20201016_211958.jpg 20201016_212429.jpg
  3. QUAKE_WARS
    2,191
    253
    Dec 19, 2008
    Coadster32 and GoldenOne7710 like this.
  4. gramps
    gramps Veteran Member
    1,541
    952
    Jul 5, 2009
    mankato, mn
    Nice lookin truck. Love those square bodies.
    unfortunately that’s a problem with flex fans. Take a paperclip and bend it back and forth a few times, it breaks off. Same thing happens to the flex fans, especially at high rpm. I’d venture a guess if you looked at the box it came in it probably says “for use under [insert some ridiculously low rpm like 3k] rpm only”
    had one guy come in and after the 4th fan he was “defect” warranty returning i happened to be up at the front counter and heard him say every time he shifts at 5000 the pos fan lets go.
  5. Lowend
    15,656
    832
    Mar 25, 1999
    San Jose, CA, USA
    This is the exact reason I dislike flex fans.
    FYI electric fans need to be on the engine side of the radiator to work properly. It’s much more efficient to draw the air through the radiator than push it against.
  6. biker
    biker Veteran Member
    2,141
    768
    Dec 7, 2014
    Ouch. Beautiful truck! So the pulley/shaft broke...not necessarily the fault of the fan, but as the other guys said, flex fans are generally garbage. I'd guess that pulley/shaft was never engineered to support the load that a fan can put on them, especially a questionably balanced flex fan hanging off the end of a 3" spacer.
    As Lowend said, if you use a properly sized electric fan to pull air from the engine side, that is way better than a push fan, and certainly better than a flex fan.
    The right electric fan(s) and shroud will work perfectly and look clean under your hood. A flex fan just screams cheap when you pop the hood open.
  7. CorkyE
    10,909
    689
    I used a flex fan on my 65 pickup with the original engine from my 79 Z-28. That was a short lived situation, too much noise and vibration. I tossed it in the dumpster, didn't want to see my, or anyone else's hood, radiator, and whatever else destroyed.
    You can get a set of LS1 electric fans for around $125 from EvilBay. I'm using these on my Camaro now.
    Nice looking square body, good luck with this.
  8. carhead22000
    carhead22000 oldblue
    75
    33
    Sep 5, 2011
    canada
    lost a fan blade on my Camaro. Soon as I hit second gear on the shift kit it popped right through my air induction hood. Thought I broke a motor mount.lol..them fans are crap.i went with electric fan after that. Never looked back.
  9. biker
    2,141
    768
    Dec 7, 2014
    LS1 fans are my next upgrade too.
  10. GoldenOne7710
    5,257
    690
    Jun 23, 2004
    Athens, GA
    That's some serious carnage. Put me down as another who dislikes rigid mount fans...especially Flex fans. I'll take a good ol clutch fan any day.
